Question about GE Refrigerators
Running warm. how do I recharge freon?
Fridge is running a bit warm and just cannot get temp down into acceptible range for freezer and refridge sides. Most of freezer- isnt. how do I recharge freon? I have r134a and a hose, worked in my cars... how/where to connect for fridge, if possible? Can't see quick-connectors.
  • GE Master
  • 3,361 Answers
There are no service valves on refrigerators for charging.(They must be added).
It may not be a refrigerant problem.
Is the freezer fan motor running?
Is there a frost/ice buildup on the back wall of the freezer?
Is the compressor fan motor running?
Is the compressor Running?
These are the first steps to verify before suspecting a refrigerant leak.
Posted on Sep 05, 2009
Why are my fridge and freezer to warm?
Sounds to me like your freon is low. That is the gas fridges use to cool things down.
I may be wrong but I would get a repair man to check the freon pressure first.. Low freon is caused by a small leak in one of the lines or in the compressor its self. I had an old fridge and the freon went low just over time.and had to be topped up.
Jan 13, 2015 | GE Refrigerators
Sub zero 690-temp
Have you adjusted your thermostat to try to get a bit colder?
May 16, 2008 | Sub-Zero 690 Side by Side Refrigerator
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Zanussi freezone fridge freezer
well asuming you already thought to turn the thermostat down, i would check to see if you have a freon leak. with the fridge running, paint the coils with soapy water untill you see bubbles. mark that spot and dry off the area around it. generously apply electronics grade solder to the area where the leak is. (be sure you don't melt the copper and unplug the fridge first) then continue untill you have checked the entire length of coil. when all ieaks have been stoped recharge with recomended freon.
Aug 17, 2009 | Refrigerators
Does not seem to be cold enough ten yrs old
Hi, first check your coils on the back and make sure they are clean, then check the cover on the front bottom and make sure it is clean. If it is all clean and still running warm then it may need to be recharged with freon. At that point you should contact a heating/cooling technician to come out and recharge your system. They are the only ones licenced to handle the freon to recharge your cooling system on the fridge.
Aug 11, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore refrigerator model 106 will not cool fridge or freezer
is your refridge leveled if not level it and stable. Try turn it off for a couples of hours and then put it back. does the refridge move a lot when u open it fix this refridge doesn't has to be moving when opening when on and moving this agitates the freon creates more pressure so it has a pressure switch and turns off the compressor to protect it from over or under pressure
Jul 24, 2009 | Kenmore Refrigerators
Freezer not freezing
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
664 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
