Question about Acer Aspire 5500 5570-2609 Laptop
Lost sound I lost sound... I am not muted anywhere.  I did try to connect external speakers and then lost sound all together.
  • 24 Answers
First check the controlpanel there is an option to take Sounds And Audio Devices Properties. then click on the AUDIO tab, check the Default Sound Playback Device.select the correct Audio divice.if the problem persist do the driver for sound ( multimeadia audio driver) from the acer driver cd.then try.
Posted on Dec 08, 2007
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
I have not sound
hi..
  • Check cables to speakers are properly connected
  • If External Speakers are used , check speakers are connected to an external power source.
  • Drivers for Audio ICs (Sound Card) are properly installed and working
  • Check Speaker Volume is not set to too low or mute
Mar 24, 2011 | Microsoft Windows XP Professional
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
I lost the sound
FIRST OF ALL CHECK THE SOUND SYMBOL OPTION ON THE SYSTEM TRAY IF IT IS IN MUTE AND ALSO RIGHT CLICK ON THE SOUND SYMBOL TO GO TO THE MIXER TO CHECK IF ANY MUTE OPTION IS CHECKED IF EVERY THING IS OK,THEN THERE MIGHT BE A PROBLEM WITH THE SPEAKERS TO CHECK THAT INSERT A EARPHONE AND TRY TO PLAY A SONG AND SEE IF YOU CAN HEAR IT IF YES AND WITH THE EXTERNAL SPEAKERS WITHOUT THE EARPHONE IS NOT WORKING THEN THERE IS A PROBLEM WITH THE SPEAKERS.
MOST OF ALL THE SPEAKERS COULD BE IN MUTE.
Oct 22, 2010 | Compaq Presario 700 470024-192 Notebook
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
Dell computer seems to have lost it's external sound
This could happen for several reasons. Of course, the first is that the speakers might have gone bad, but that is not usually the case.
The next reason would be if you have muted the speakers in the "sounds" option in the control panel. Check that. While there, be sure you have the volume up and not way down.
Jan 05, 2010 | Dell Inspiron 1525 Laptop
Computer speakers work but external speakers do not
Schuttie
hello there!
First Things First:
1) Check if your external Speakers are connected on the external sound card output connector **
2) Check on control panel and multimedia if your sound card (external) is enable, and not MUTED sound. Rise the volume.
3) check cables from Speakers and see if not old or broke.
Good Luck
Feb 09, 2008 | Audio Players & Recorders
No sound
Your sound card is not working! It might due to driver or hardware failure. Try to reinstall clean copy of your sound driver! you can check your device status in Controlpanel/device manager!
Dec 08, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
