Slimy mold in rubber seal
The Miele W 2104 washing machine door's rubber seal doesn't properly drain, water tis trapped in the seal, and mold develops, causing a strong smell that permeates the clothes after the washing cycle.The cause for the strong smell took a while to figure out. I suspect this is a design fault - I've ordered a new seal, which I still haven't placed, fearing the same phenomenon will occur. Can you please help me find a solution to this design fault?
    Problem Solver:
  • 7 Answers
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Posted on Sep 06, 2009
I have a Frigidaire front loading washer that is beginning to smell and I thought I should check the "outlet filter." Well it doesn't appear I have one or hopefully I just can't find it.
It could be where the drain pipe is going into the drain.
A lot of machines drain into the water system are not sealed. (ie pipe just fits in and there is an air gap).
You can get fittings that seal the gap so you dont get smells.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Hi, can u show me how to clean my washer to get rid of that moldy smell. there's also mold around the rubber ring around the opening and it feels slimy. Can u please help
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back, in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump or try this one for cleaning a ge drain pump filter and this one for cleaning/replacing a Kenmore drain pump
Oct 07, 2010 | Maytag Neptune MAH9500A Front Load Washer
Heavy mold build up around rubber boot inside and out. clothes smell moldy when taken from finished cycle kenmore elite he4t model...
The following link can give you some advice on common causes of front loader washer odors and some preventive measures you can take to keep them from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most common causes of persistent odors comes from not leaving the door OPEN between washes. The manufacturer recommends this to allow the wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL. Leaving the door open will NOT make this water evaporate, but will allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the rubber door bellow and/or drain pump. It is recommended that you pull back the rubber folds in the door bellow (gray rubber seal) and check for dirt, debris or small articles of clothing that may have become trapped there. Socks are a common thing that become trapped, and if left for a long period of time, become stagnant. The drain pump reservoir is another common place for things to collect and become stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
You can use use a 50/50 mix of bleach and water to clean the door bellow thoroughly with a scrubbing pad to get rid of mold and mildew. Use the green kitchen type scrub pads as they are not as abrasive. Do not use steel wool. If the mold becomes permiated in the rubber and will not come off, you will need to replace the bellow to get rid of it. The following link explains how: http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load Replacement parts (if required) can be purchased from any of the following websites: searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
All these are preventive measures that can drastically prevent odors, mold and mildew. Read through the advice given and post back and let me kow if you require additional assistance. I hope you find this information helpful.
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
Moldy mildew smell
Aug 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do mi get rid of the rotten smell from my duete washer
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After wash is completed there is water remaining in the rubber gasket which caused mold to form with a bad odor. Is t5here something I am doing wrong?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@%%
May 21, 2010 | Miele W865 Front Load Washer
My miele w3033 has mold in the rubber gasket. wha...
hi,
you can purchase a cleaning product to run through the machine but white vinegar on a 95c wash also works.don't put any clothes in it though. if it has eaten into the door seal too much you can easily have them replaced. always leave the door open after each wash for about half an hour to let it dry out otherwise a damp environment is perfect for bacteria to develop. lots of hot washes and the door open prevents this.
May 19, 2010 | Miele W2240 Front Load Washer
Beko sma 510 washing machine clothes smell when cycle is finished
Oct 16, 2009 | Washing Machines
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Aug 24, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
444 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
