Question about Kenmore 24902 Top Load Washer
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
I've already had the switch replaced and it didn't fix it.
  • James Hilton
    James Hilton May 11, 2010
    I can't make since of the question. If you can give me a complete model number from around the lip where you load the clothes. Plus the problem your having, I'll be glade to help you.
    President:
  • 1,382 Answers
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Sep 05, 2009
Kenmore Series 80 Washer Drips and Spin Cycle Sometimes Has Low Torque
Does it leak every time it's run, or only occasionally? It could be that the belt on the drain pump is going bad or is loose, so it works some times but not always. Could be that the belt broke or the drain failed, so it will always leak from now on. It's hard to say without actually taking it apart and having a look
Dec 31, 2012 | Kenmore Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series washer will not drain or spin but will fill up how to fix it
The usual thing wrong when a washer such as the one ya have doesn't spin or drain,it's going ot be a broken lid switch. Its a pretty common thing so i have written this tip of how to check for a broken lid switch, http://www1.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Oct 10, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Jan 14, 2008 | GE WSM2700D Top Load Stacked Washer /...
Kenmore 24902 Top Load Washer Logo
327 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
