Question about Cooktops
Clicking sound continues after flame is ignited
    Novelist:
  • 222 Answers
Hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
phillipines
Posted on Sep 13, 2009
5 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Clicking
Tke the top of of the burner and make sure the nut below it holding the whole thing together is tight. Occasionally these cooktops will have that nut come loose, letting the flame leak a little air in or it will discolor the cooktop around the burner. If you have this discoloration, you probably need to take the whole thing apart and replace all the o rings, as the discoloration is usally from the flame leaking out under the cooktop. Also, take some fine sandpaper and polish up the end of the little igniter to make sure it can sense the flame properly. Last of all, how old is this model? A couple years (not exactly sure which models, call dacor) ago there were a few of these cooktops that hadclicking issues that just couldnt be fixed, and if your is the affected model/serial they may give you a new one.Good Luck!
Posted on Dec 10, 2006
dauphine
  • 207 Answers
SOURCE: No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Posted on Apr 09, 2008
  • 150 Answers
SOURCE: igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Posted on Apr 23, 2008
  • 10865 Answers
SOURCE: ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Posted on Jul 24, 2009
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Click sound that kick starts the flame is continuing even after the flame has been made how do I stop the clicking sound of the pilot?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 16, 2011 | GE Cooktops
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
After igniting the cooktop, the cooktop continue to click as if it is still trying to ignite the flame. The cooktop starts fine but it continues to click.
its probably these switches that sit under the gas valve controls. One for each one. They can go faulty and stick on. Make sure these are the exact one for your model before deciding on anything.
http://www.appliancepartspros.com/part_details.aspx?part_id=3191247
May 04, 2011 | GE 30 in. JGP326 Gas Cooktop
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Pot overflowed and then flames from R side and clicking
yes this is commen when you spill liquid on the spark module what happens is it grounds itself out and will continue to spark until it drys out. you should be fine.
Jun 20, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
No Ignition
Mar 14, 2008 | Cooktops
Clicking
In addition to polishing up the end of the igniter as mentioned above, remove the burner cap cover and and the round burner cap. As noted above, electrical contact or grounding is an important element in the spark igniter function. Any poor contact surface can cause the igniters to continue to spark after a burner lites. If everything seems in order, polish the underside of the aluminum burner cap and the top side of the aluminum burner base (where they come in contact with each other). This is part of the grounding circuit for the igniters. I used an "SOS" pad. In our case, these parts had tarnished with age. My wife was very happy when I fixed this one.
Dec 09, 2006 | Dacor Preference SGM365SS Gas Cooktop
Cooktops Logo
438 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
