Question about Sangean ATS 818 AM/FM/SW Radio
Bought an ATS 818 at an auction but it was 'deaf' on AM and SW. I worked out I needed to replace Q1 and Q2 and this restored the preamp. Question: is it safe to use longwire antennas on this radio? Due to static probs etc,.
  • radiorob1
    radiorob1 May 11, 2010
    That all depends. How long is the antenna? Do you live in Florida, or where there are many electrical storms? Do you leave the antenna plugged in all the time? Do you use a lightning arrestor / antenna surge protector? How is the antenna connected? Rob
SOURCE: ATS 818 Inoperative
I believe this is what you are looking for.
Posted on Oct 11, 2008
radiorob1
  • 17 Answers
SOURCE: Sangean ATS 808A-replacement aerial antenna
The antenna should be available from Sangean, or C.Crane.
To replace the entire antenna, about 6 screws from the back must be removed, and the back also removed.
Or you could replace it at the antenna's "elbow". However, this is almost impossible to do without loosing the 2 tiny washers. If you do loose the washers, the antenna will work, but will be loose, and not stand up and support itself.
Posted on Aug 04, 2009
kb8dns
  • 494 Answers
SOURCE: I have broken the aerial on the radio SANGEAN ATS
Radio Shack sold the same radio as the DX-390 and parts may be gotten from there.
Posted on Feb 09, 2010
SOURCE: My Sangean ATS 808 AM/FM/SW Radio reciever shows a
Hello, I assume that this only happens when you are using it on batteries and the unit works when plugged into the mains. If this is the case it most likely is a faulty or dirty connection in the main battery chamber. Clean all contacts reload new batteries and try again.
Posted on Dec 22, 2010
  • 7 Answers
SOURCE: Need operators manual for sangean
I suggest you go here... http://groups.yahoo.com/group/sangean818cs/ ... and join this group, then look in the files section...joe..
Posted on Jan 14, 2011
Eton e5 sw shot
The SW FET preamp transistor, Q1, on the underside of the circuit board blows if a static electric discharge hits the whip antenna. In my case, a cat rubbing against me & the radio on a very dry winter day did it in. The back & circuit board has to be removed to get at it. The micro transistor & the solder connection are very tiny, so hard to replace. The antenna jack should still work, because the preamp is only for the whip antenna's SW reception. An easier solution would be to just run a wire from the antenna jack to the whip antenna, but you would no longer have the whip's preamp benefits, or just use a longwire antenna connected to the jack for SW. Also beware plugging into the jack disables the AM ferrite antenna inside, so you might not want anything plugged into it for AM reception because the internal ferrite seems to perform better than any external antenna.
Jan 17, 2013 | Eton E5 Radio
Need operators manual for sangean 818 cs sw radio, Thanks, Rich. deek@sbcglobal.net
Jan 11, 2011 | Sangean ATS 818 AM/FM/SW Radio
Wiring schematic for Sangean ATS 818cs
Yes, go to:
www.thiecom.de/ftp/sangean/ats818/ats818acs-servicemanual.pdf
Jan 01, 2009 | Sangean ATS 818 AM/FM/SW Radio
BFO
If it worked before, and you could tune SSB, the BFO switch is probably broken.
Mar 27, 2008 | Sangean ATS 818 AM/FM/SW Radio
WX cc Sangean radio cuts out
The ATS-818 needs a transformer. The transformer converts AC power to the DC used by the radio, so no. You need the transformer.
Jan 20, 2008 | Sangean ATS 818 AM/FM/SW Radio
ATS 818 Inoperative
Unplug AC adapter from radio. Remove ALL batteries. Wait 15 min. Reinstall batteries
Jan 17, 2008 | Sangean ATS 818 AM/FM/SW Radio
Power problem
Look at right side of radio. Just above the volume knob is the keypad lock switch. Just switch it to the other postition. Should work fine.
Dec 08, 2007 | Sangean ATS 818 AM/FM/SW Radio
Power Button Snafu
I think the E means a dead battery. You could have intermittent solder connection on your DC input jack. This could effect battery operation as well. Check for bad connections and resolder also look for broken traces at these connections. Good luck.
Nov 17, 2006 | Sangean ATS 818 AM/FM/SW Radio
Sangean ATS 818 AM/FM/SW Radio Logo
119 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
