Question about iLO V27DMBX Television
Ilo tv will not turn
Tv will not turn on.for awhile you could up unplug and re plug it in.now it will not work red light is on.but, after it is on you can turn it on and off. but only if a few second in between
  • iLO Master
  • 19,396 Answers
The red light flashing means protection mode because an internal fault had been detected.
If the TV does not even start after unplugging power cord for a while, then the defective part must be replaced.
Parts that are commonly faulty are PSU, Inverter , and LCD control board.
Parts must be tested before replacement.
Posted on Sep 05, 2009
  • waynebyras Nov 06, 2010
    thank you very much Ginko you really helped us out....
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Posted on Sep 09, 2009
budmrtn
  • 11361 Answers
SOURCE: our ilo tv will not turn on. we have replaced the
So hittin the power switch on the TV and all you get is the blink red light. You are going to have to open it up and inspect the inside, start at power supply module.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 11, 2010
budmrtn
  • 11361 Answers
SOURCE: Ilo 27" TV will not
That can be the main board get EPROM scramble, then you reset it when you unplug the TV. It can be caused by spike in the power line or unstable DC in the power supply due to bad DC filter caps.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 08, 2010
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
Ilo tv will not turn on. I was able to unplug the tv, plug it back in and then it would turn on. Now, nothing works.
is there power came from your outlet if yes then check your power filter fuse if OK then check your audio board because it act as output and crossover power that is depend only if you have red light on,also check your power supply board for blown capacitors. also get another opinion good luck.
Apr 28, 2010 | iLO 2600 Television
My ilo rc-370c wont turn on.the red light just blinks????????
If you get a flash on the red light when you try to turn it on and hear a popping noise. Unplug it then use a hair dryer to heat the inverter up on the right side (power button side) of the tv (up through the vents in the back for 10-15 mins). Plug it back in and turn on.
Apr 05, 2010 | iLO 3200 32 in. LCD Television
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The ILO tv will not come on at all
tv clicks on but no picture, red light flashes awhile than goes off.
Mar 23, 2009 | iLO 3200 32 in. LCD Television
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
TV wont' turn on
The failure on your LCD is due to a defective power supply. Leaky or dry capacitors is the reason for the failure. Replacing or repairing the power supply should fix your LCD.
Contact this website and ask them if they have any power supplies in stock.
Good Luck.
Sep 04, 2008 | iLO LCT32HA36 Television
iLO V27DMBX Television Logo
473 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
