Question about Philips 200WB7 (Silver) Monitor
Backlight out on Philips 200WB monitor
I have this exact problem - although I did not experience a recovery yet. Mine is exactly the same age. It just stopped working yesterday, although the green led on the power button stays green, and the video card still sees it, even after doing "Detect Displays" (I am on a Mac Pro). I can still move windows to it. It must be working still, except for the backlight. I went through the same cable replacements and power cable changes.
  • 1,684 Answers
It sounds like the inverter is out on the power supply for the backlights. If you can open the monitor and take a few pictures of the boards and send them to tech@ccl-la.com I will try to cross reference the boards and give you a repair solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 10, 2009
My sony pcg-71912L screen got cracked so I ordered a new one. My nephew put it on for me but no backlight. He said he could find no place to plug it into. I have hooked it to an external monitor and i
I believe you have an LED screen which does not require a CCFL bulb to enable the backlight - the reason it doesn't have a place to plug in. Make sure you have ordered the correct screen. Verify exactly which type of screen you need by checking with Sony.
Feb 06, 2013 | Sony Vaio Pcg- 71912l Laptop Screen 15.6...
Hp ze5570us screen flicker i think loose conection
There is a ribbon cable that is in the rear of the monitor, also a backlight CCL, If your laptop is getting on in age it could be the Graphic Card. It hard to diagnose exactly.
Nov 08, 2012 | Computers & Internet
Hi, The problem with my Monitor is that after the
That LCD monitor uses a fluorescent backlight, and the symptom you are seeing probably means the backlight is failing. There are two possible problems:
1) Likely: The inverter board is failing. The inverter creates the high voltage needed to run the backlight and can shut down after a short time if the board is failing.
2) Less likely: The fluorescent tubes themselves are failing. This usually requires replacing the whole LCD screen, although experienced technicians can disassemble the LCD screen and change the bulbs. This is much riskier.
The best bet is to replace the whole monitor. If you are willing to take apart the monitor and try a repair, you may be able to get an inverter and fix the problem.
Sellers on eBay usually carry a lot of models of inverters and may be able to sell you one and guide you through a replacement. However, this is a moderately advanced repair.
Search for the HP exact model and "inverter" on eBay
Apr 11, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Benq fp222w monitor switches on but black screen no backlight what parts need replacing to fix pls
If there's no backlighting but you can see the image anyway, then your monitor might have a defective inverter. The inverter is responsible for providing power to the backlight, so if it is defective, the light won't work and it might need to be replaced.
An LCD inverter looks something like this:
You can easily find inverters for sale online, but be careful: you have to find the exact same inverter for your monitor, or it may not work.
Mar 02, 2011 | BenQ FP222W LCD Monitor
Tv is black when turning on tv
well i have the exact same problem with my tv... was told i need a power supply, an ssb mainboard, a y buffer board and a y main board.................. sucks!!!!!!!!!!
Sep 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
Same exact problem.
Hi!
If the camera shows the menu very dark too, could be a dead display backlight fuse. If you have experience with soldering and a multimeter, you can contact me at toms.safranovs@gmail.com and I can help you locate the fuse on the main board. Otherwise, contact your local Sony service center.
Tom
Jul 28, 2009 | Sony Cybershot S650 Digital Camera
No Image but power
find the manufature of the video card, use the old monitor and go to the video card manufacture and download the video driver.
Jun 30, 2008 | Philips 170B4MG 17" LCD Monitor
Backlight is acting like a bad flour. tube .. everthing else OK
Normaly the backlights have a life of around 40k hours of working.
If your monitor is 3-4 years ,the backlight tube/s could be defective.Your description seems to indicate tube aging.
It's possible to replace the tube but needs a good amount of technical skill.
Do write if you need more help,Please indicate make exact model no etc.
Samir
Mar 22, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Hp flat panel monitor looses picture
Here
Here
and Here
I've tried all the aforementioned fixes, and my conclusion is... when your monitor's dead it's dead. Go to NewEgg and and get a new one.
Nov 12, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Problem in monitor
Sounds like the inverter board or lamps are bad
Feb 26, 2007 | Dell E173FP 17" LCD Monitor
Philips 200WB7 (Silver) Monitor Logo
1,017 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
