Question about Dell E176FP 17" LCD Monitor
My dell lcd monitor will not stay on - Dell E176FP 17" LCD Monitor
  • alc03 May 11, 2010
    It is probably not your monitor but the PC that is not correct, It could be the video adapter or even your computer that does not boot properly du of a memory problem. In fact, many things can cause that. But first verify all your connection around the PC, make sure the PC boot properly then you will be able to eleminate many possibilities.
    Scholar:
  • 53 Answers
If the problem related to wrong PC (video adapter) settings, during boot-up, right after BIOS started, press F8 button to call OS startup menu, choose there 'VGA Mode', then OS will be loaded with basic VGA settings (640x480 250 colors), so you will be able to set other display settings, proper for your monitor.
But all that, of course, won't be possible if the monitor itself shuts down, that would be completely different story.
Confirm what exactly is wrong, Display Settings or the monitor itself?
Posted on Sep 09, 2009
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell monitor will come on but will not stay on. stays on 5sec
5 seconds? Hmm, too long for inverter driver turning into protection caused by bad lamps. Also too long for PWM controller in the switching power supply.
Rather looks like overheating of the FETs in the inverter, they are driving HV-transformers. Open the monitor, remove metal lid and observe inverter board. If PCB under and around these FETs is darkened, replace them.
These Dells hard to open. Take the foot off and unscrew plastic cover. Then using flat screwdriver with wide blade separate plastic halves of the case, starting from bottom edge and moving to opposite. It might be sweaty.
Sep 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E176FP 17" LCD Monitor Logo
428 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
