Question about NEC Z1 (845625) PC Desktop
Hard drive does not get identified. auto does not auto detect
Need to know the hard drive parameters so the system will detect and boot so that I can restore to factor setting with factory disk
  • xCAUSALITYx
    xCAUSALITYx May 11, 2010
    Hi, What error do you get on boot? Thanks
  • 3,153 Answers
Set the BIOS to auto for the hard drive and it should find it and set it as needed.
If it still does not find it there is a chance that any problem may be with the hard drive itself.
Posted on Sep 05, 2009
Parameter out of normal operating range, computer will not boot up
Probably need to replace the hard drive and reinstall your operating system. Can you boot from a cd? Do a hard drive test and post the results.
Feb 24, 2014 | Microsoft Windows Vista Home Premium with...
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
Not detecting hard drive
Need to know what operating system you are using. Win XP should see the external (I'm assuming it's a USB drive). Are you sure the USB port is working? Try another.
You may have to right-click on My Computer, and choose Manage from the menu. Go to disk management to see if the computer sees the device (probably Disk 1 for you). You may have to enable it.
Mar 11, 2009 | Compaq Presario 3045US Notebook
Sony laptop won't detect hard drive
If the drive hasn't been formatted, that is normal. On some systems, you also have to force the BIOS to recognize the drive by entering the BIOS setup (check with Sony or manual to learn the key needed). Once you know the proper key to tap at power on (it varies, sometimes F1, F2, Esc - who knows?), you will be presented with a simple text screen with a number of different selectable items. Choose 'Set factory defaults' and the BIOS should look for the drive and set the parameters for you. If that still doesn't work, check through the other BIOS items and you should find 'Detect fixed (or hard) drive.'
Sometimes installing a larger drive than the original can cause problems and if the BIOS is older, it may set the drive parameters of the original drive and ignore the excess capacity.
Mar 01, 2009 | Sony VAIO K15 Notebook
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
My pc will not load up with windows xp eventually got into the bios page & found the hard drive didnt show up as been identified
Read this whole post you might want to try the last paragraph first.
Take your hard drive out of your computer. In another system configure that hard drive as a master using the jumpers on the back of the drive the configuration should be on the drive itself although it is sometimes obscured.
Set your drive as a slave, again with the jumpers. Install your hard drive and boot the system up.
If the other system does not boot up or if it boots up and cannot detect your hard drive or your hard drive appears empty it is bad. You have to replace it.
If you are successful in seeing with folders, remove the cmos battery from your system for 30 seconds then reinstall and boot it up. This will place your bios to factory defaults and it may detect it.
Mar 07, 2008 | Computers & Internet
Update on Boot up problem with Versa P600
I have had this problem many many times at the Lab over the years, in fact I have even owned a PC that did exactly as you describe! ... What I found out was... SOME hard Drives seem to work OK, others??? It seems to be a "Timing" issue with the Hard Disk Controller.. There is NO FIX as such.. that I have ever found, Sometimes ya can find a brand of Drive that will work with.. ALWAYS.. but for the most part.. it's either put up with it.. OR get a new motherboard/PC. I have torn my hair out more than once as I said.. But essentially it is a Motherboard fault, specifically, the Hard Drive Controller, thats is at fault..
Aug 16, 2007 | Intel Motherboard
NEC Z1 (845625) PC Desktop Logo
201 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
