PC show the message and hang and black screen .
After  switch  on  my    desktop  computer ,  the   computer   beep , the  screen show  the  following  message -" Intel  845 GL   AGP   Set  BIOS   for  8LS533   F2    Zenith"  and  then  hang  up   showing  the   black   screen.  When   try  to  restart     there   is  no   beep   sound  and   the  black   screen    although   the  power  led  on   the  CPU   is  glowing .    I   tried   several   time  but  no   beep   . Refresh  my  memory  card  and
check  the  fan   and  video  card   but  same  result . .Please  help.
  • 3,153 Answers
You are going to have to start with basic troubleshooting first.
TAKE notes as to where cables were etc. (digital camera would be useful here)
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the on-board)
Disconnect all drives
Power u the computer and make sure you can at least get into the BIOS.
If you hear any beeps these can indicate where the fault is.
Power up the PC and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
If its not the PSU and your fans are working it may suggest a problem with either the motherboard or CPU
Posted on Sep 05, 2009
How do I retrieve photos on my hp pavilion 325c? When I try to turn the desktop on a light blink under the power button
The light blinking under the power button is Hard Drive activity which is normal. Do you have the monitor plugged in and switched on?
Nov 01, 2017 | HP Computers & Internet
Will not start up correctly
Try starting in Safe Mode by pressing F8 during boot, and lower Screen Resolution.
Oct 03, 2012 | HEWLETT-PACKARD Pavilion p6331p PC Desktop
Desktop screen
try booting in safe mode and see if the screen displays properly.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the 1 inch black space then your video card might be going bad or you might have a virus infection. If the Borrowed monitor displays ok then your original monitor is bad.
May 29, 2012 | Dell Inspiron 530 Desktop Computer...
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
What's your problem?i have a dell optiplex 755 (tower).. it was working fine.. but one day when switched it on,, it doesnt behave normal.. and no screen was showing on the monitor.. the pc was sho
Welcome to the world of Windows 7. Don't you miss Windows XP? LOL, Windows 7 is a nightmare just like Vista.
Anyway I think it's your Memory. You mentioned moving the memory chips around, but you didn't mention trying one at a time. I think one of them is bad.
Memory ChipRemove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Try just working with one of them in Slot 1 and swap them out in just Slot 1.
Oh, I just thought of something else, Maybe you have bad Capacitors on the motherboard. Remove the Power Cord, Remove the Case. Take a flash light and look inside the computer at the capacitors. They look like little Battery Towers. If any of them are spewing corrosion out of them, they can cause the computer to go crazy just like yours is doing.
Apr 22, 2012 | Dell Computers & Internet
My 531S hangs at the dell splash screen with one short beep before loading windows vista
I would start the computer in safe mode. To do this, keep tapping on the F8 key as you start the computer. Do this as soon as you see anything on the screen. If you get the windows splash screen, you've waited too long. Once you get the white menu on a black screen, choose safe mode and let it start. The next time you do a restart, it should work. If it doesn't, then in safe mode do a system restore back to the time it worked.
Apr 06, 2012 | Dell I531S-2809 PC Desktop
I have a sanyo model dp32670 and when I plug my pc into it as a monitor, the startup screen shows and shortly after the desktop shows up the screen goes black. It is not the pc as the other screen works...
The problem is in the power supply section, there are one or two bad capacitors that have opened, sometimes they will bulge at the top making it easy to spot.
Apr 01, 2012 | Computers & Internet
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
