Question about Nintendo DS Lite Console
My ds will turn on but no sound or display
I will try eventually to leave it on until the battery runs out but it always has full power all the time no sound no display nothing... once i tried wiping my sceen with a really wet paper towl my uncle tried to fix but it only worked for a few days then did this help please!!
  • 20 Answers
I'm guessing that the battery is overloaded. This might happen if you didn't use Nintendo brand charger/ battery. Buy a new battery or a new console. I wouldn't know, the only issues I have had with my ds lite is freezing games from using action replay.
Posted on Sep 05, 2009
Have tried to reset. Did not work. Have tried several outlets. Did not work. How do I chcek the battery.
It would help knowing what operating system is I.e. Windows 7 or 8.can you get into safe mode by repeatedly tapping f8 this should give you drop down menu for last known good configuration.choose this to see if the laptop returns you to a desktop.the battery can be checked by leaving the power supply in until you get to the open screen desktop then remove power supply and check the icon for battery bottom right.if you hover the cursor over the icon it will give battery life in percentage.batteries eventually fail mainly because people do not charge them properly.you need to run it flat occasionally and do a full recharge.once it reaches 100% take the power supply off and run it down to 20% and charge back to 80 % half a dozen times in between full charges?also in control panel there is an icon for battery whereby you can force the battery to discharge so you can re educate the full charge memory,this usually increases the stamina of a failing battery.
Apr 12, 2015 | Computers & Internet
My Nintendo DS quit playing sound through the speakers. It only has sound through headphones. One minute it was working then the battery went dead. After I plugged it to the charger the sound does not...
Try leaving the DS on until the battery dies, then charge it all of the way with the DS off. If that doesn't work, I would call Nintendo customer service. They are excellent at helping people with problems just like this. Here is the 800 number I got off of their website. 1-800-895-1672
May 03, 2011 | Nintendo DS Lite Console
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Unable to charge battery
Well, yes there is a solution to this, but it still will cost you some bucks.
This sounds like you have a bad battery.
Usually when you have a bad charger, the same things happen that you describe. Only difference is your system won't come back on if the battery has fully died.
In your situation the battery does come on, but not for long. Which leads me to believe your charger is still working, however your defective battery is only being charged to a certain level.
I would recommend you use another battery with the same charger and see if you get the same results.
IF YOU DO..
Try a different charger.
If you're still experiencing the same results with a new charger and battery, then I'm afraid the problem is your charging port. If so, you would have to have this system repaired.
I wish you luck and hope I helped!
- Great
Apr 13, 2010 | Nintendo DS Lite Console
Nintendo ds clock not working
i had some trouble with my ds, and so i killed the battery. you have to stop charging it and leave it on with full sound to down the battery faster. keep doing this untill when you turn it on it shuts off by it's self imediately. leave it alone for a week or so and then check and see if you can turn it back on. if it won't even light up for a moment when you hit power you've done it right.
WARNING: this will erase all saved data for all games on the ds.
you can now plug it into the wall and let it charge for at least 5mins. keep it pulgged in and turn it on. it should show the settings menu for birthday,time,etc. just like when you first took it out of the box.
this will reset the ds to factory settings, and should alow you to change the time.
NOTE: only do this if the time is REALLY bothering you.
Jul 31, 2009 | Nintendo DS Console
My Nintendo DS won't stay on.
try charging it, or if that doesnt work,the battery might be in incorrectly, or one of the battery pins is broken or bent.if the battery is in incorrectly try putting it in again.if one of the pins is bent try carefully bending it back.if one is bro0ken,you might consider a new DS.there could also be forien material in thew battery compartment, in which case you would extract.if none of these solutions work,it might either be the battery(in which case you would buy a new one)or an intenal problem (which would lead me to consider a new DS)
Dec 26, 2008 | Nintendo DS Lite Console
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Blank white screen
Try using some alcohol to clean the contacts of the card and leave some on and reinsert a few times - leave to evaporate and try again - sounds like dirty contacts!
Sep 16, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
113 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
