Question about Fargo DTC550 Thermal Card Printer
Printer ok,my problem is the printer main setup number/figuresvery difficult to set and unable to full card when printing
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
Brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Dec 04, 2007 | Brother MFC 420CN All-In-One InkJet...
I have a MP280 printer/scanner/copier that prints my photos out to dark, when it is on the computer it is pefect colour
Select the manual color adjustment (or if already in manual and it had initially been printing fine, you may opt to select Auto)
On the Main tab, select Manual for Color/Intensity, and click Set....
The Manual Color Adjustment dialog box opens.
Specify the brightness
Select Light, Normal, or Dark for Brightness, and click OK.
The current settings are displayed in the settings preview on the left side of the printer driver.
Complete the setup
Click OK on the Main tab.
When you execute print, the data is printed at the specified brightness.
May 16, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
  9. Check the printed pattern
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
  15. Check the printed pattern
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
I want to print onto christmas cards, how can I set up my HP photosmart 2610 to do this
To apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
Dec 03, 2010 | HP Office Equipment & Supplies
ONLY A NARROW IMAGE OF A 'SKETCH-UP' WILL PRINT ACROSS THE MIDDLE OF THE PAPER, WHEN I WOULD LIKE A FULL PAGE (BOARDERLESS) IN LANDSCAPE ORIENTATION. WHAT SETTING AM I MISSING?
Before printing, configure the page setup on the application where you're printing from. Go to File -> Page Setup -> select Landscape orientation -> hit OK to save the setting.
To print your sketch, go to File -> Print -> Preferences/Properties -> from the Page Setup tab, select Landscape orientation -> from the Print Layout tab, select Borderless -> click OK to save the settings -> click OK to start printing.
I hope this information has been helpful.
If you need additional assistance, please contact Lexmark technical support.
Nov 24, 2010 | Lexmark X2580 Wireless All-in-One InkJet...
!FRAME NO. FULL
Save all pictures to your computer.
Turn camera on, press the menu/ok button, select Setup, press ok.
select Frame No., change Frame No. to Renew, press ok.
Leave Setup.
Press the menu/ok button, select Setup, press ok again.
Select Format, press ok / ok until the card is formatted.
Now the counter should start over with 100.0001 again.
Set Frame No. back to Cont. to avoid to many images with the same filename.
Feb 22, 2010 | Fuji FinePix S5700 Digital Camera
The color ink carriage had a piece of plastic that broke off and the spring popped out. Does not close or stay closed, so i thought well, the black is still ok, I'll just print in black only. A friend...
Go under Print Settings or Check Settings and Print from there you:
1: Look for Properties button click on it
2:on my printer for example under properties its under the Main tab yours like many others might have it on the Page setup tab either way it under the properties button.
Nov 21, 2009 | Dell 922 All-In-One InkJet Printer
How do I setup a 4x6 index card for printing in Word
Click on File.
Then Click on Print.
A box should come up on the first line Name Epsen Properties
Click on Properties.
Then next Box Read Main Page Setup Effect Etc.
Click on Page Setup Then the setting change. Page Size Letter with a drop down arrow V
Click on the drop down arrow . On the 6th one is 4*6
Click on it.
Then click OK so it keep the setting.
I do hope this help you
Mar 16, 2009 | Epson Stylus C60 InkJet Printer
Fargo DTC550 Thermal Card Printer Logo
55 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
