Home | Linksys | Wireless-G WRT54G Router | Wireless network bro...
Linksys Wireless-G WRT54G Router
Problem for Linksys Wireless-G WRT54G Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
By CalWiz on Dec 08, 2007
Hardware: [LNE100TXv5]->[WRT54Gv8]->[2210-02 ]->[att yahoo dsl]
PC#1 [ PCI-NIC ] [ ROUTER ] [MODEM] [ ISP ] {XP-SP2}
PC#2 [DFE-530TX+]->[ F5D7050 ] (Belkin USB Wireless) {W2KP-SP4}
Can connect to ISP with [2210-02] or [WRT54G]->[2210-01]->[att yahoo dsl]
Can not setup network using Linksys EasyLink Advisor, doesn't see WRT54G
PC#2 does see WRT54G but can not connect to it.
PC#1 ipconfig:IP Add.:0.0.0.0, Def.Gate.:_ _ _ _, DHCP:0.0.0.0 etc
PPP adapter Dhcp: No, IP Add.:75.45.71.209,
What have I broken? I need to reset both [2210-02]&[WRT54G] to defaults and need default user,password for both to run setup programs. I've tried power down, rear reset buttons. Not tried [WRT54G] front logo button.
Same Problem
Jan 05, 2008
-   I've been dealing with similar problems for the 1.5 months i've had at&t dsl. finally this evening the at&t tech mentioned using bridge mode and enabling PPPoE on the Linksys. We'll see if this works for more than a few days.
Meanwhile, I run my home network as 192.168.XXX.YYY where XXX is not 1. Any one know how to change the Motorola 2210-02 to another group address?
-   Guest
Best Solution
posted on Dec 08, 2007
Helpful)
pasha19
Rank: Guru  Linksys Expert
Rating: 86%, 756 votes
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Was this helpful?
Yes
No
Solution #2
posted on Apr 18, 2008
Not Rated)
Ozlander
Rank: Apprentice
Rating: 0%, 0 votes
Motorola 2210-02 uses a ip address of 192.168.1.64. So I set the router ip address to 192.168.2.1 and fixed the problem of no communication between modem and router..
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G WRT54G
Questions and Unsolved Problems for Linksys Wireless-G WRT54G
Do you recommend Linksys Wireless-G WRT54G Router?
Answer
Answer
My router won't connect to my computer. I have had it for a year and thought it went though the... (More)
Answer
I have Windows XP and am trying to install HP Office Jet Pro 8500 Wireless and am getting the... (More)
Answer
Please check the wireless driver installation
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Linksys Wireless-G WRT54G...:
Top Router Experts
Rank: Guru Guru
Solutions: 1495
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
