Question about Boating
Freq change GME GX300 from 27Mhz to 29Mhz
I need to change the frequency from 27Mhz to 29Mhz for my GME GX300 CB radio Help!!
  • Anonymous Mar 15, 2014
    Just bought a second hand gme 300. Put a new 27mhz gme antenna in it and I cannot pick up any cb chatter to test set. Have power but that about all
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Posted on May 05, 2010
    Problem Solver:
  • 15 Answers
Hold down the 88/PRI key, while switching the radio on.
Posted on Sep 05, 2009
I have a connex 4800 dsl its a great cb but I need info on (buttuns,and what the ch. are in reslation to the frequency has a freq. counter on it ,but dont know which ch is what freq. can you help
  • This site does not allow a big enough spot to upload a diagram that would be beneficial for this purpose so I had to upload it off site. Since this radio is often converted to run on 11 meter (CB frequencies) the diagram I uploaded corresponds with the frequencies after conversion.
  • On the Connex radio's the band "HI/LOW" switch determine the band you are on in relation to the knob. If you want the original, stock, frequency chart let me know and I can put that up as well.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Connex 3300 240-Channels Base CB Radio
Hi, my 88 drifts off freq when it warms up. can you help?
  • Is it drifting off frequency by the radios meter or an external meter. If its the radios meter then hook up a meter externally.
Dec 26, 2010 | Galaxy Radios DX- 88HL Base CB Radio
I need a freq band chart for galaxy v radio
There's a frequency band chart for CB radios at http://www.longcom.ie/cb_frequencies.aspx
I hope this is of help to you.
Sep 17, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
HOW DO I PROGRAM MY SCANNER FOR CB FREQUENICES
Sorry, but you cannot monitor CB communications with your PRO-82. The CB frequency band is at 28 MHz, and the coverage of your scanner begins at 29MHz.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Nov 05, 2009 | Radio Shack Pro-82 Scanner
Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Sideband freq
That is wrong , I used to have a freq. counter that only read when you applied RF to it on my old Tempo rig and I ran lower 37 and upper 35 so I would key the radio on am and tune the vfo to that frequency and would be on frequency with everone else,I remember hearing that once long ago but it's not true.
Feb 21, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Frequency
You would have to replace several components on the board(requires alot of soldering and the parts needed are a little hard to come by) in order to change the output frequency ranges. It is alot of work to do this and is probably not worth all the work, Best advice I can give you is to replace it with an AM one and sell it.
Hope this helps
Sep 11, 2008 | Cobra 29 LTD CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Cobra 150GTL DX
How do you have it installed? in a vehicle? or in a building. What power supply configuration are you using? Is it adequately earthed/grounded? What type of antennas do you have? waiting for your info :)
Aug 27, 2007 | Cobra 150 GTL DX Base CB Radio
Boating Logo
1,021 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
