Question about HP DeskJet 932c InkJet Printer
Hp 932c printer when turned on moves a page
Hp 932c printer when I try to print it pulls the paper to print but then the middle (amber) light comes on. I push the middle button and the paper cycles through, the green light comes on, then it pulls the paper to print but the amber light comes on. This cycle over and over again.
We are in the middle of printing our Tax Return and an orange light keeps blinking on the top of the printer - and it has stopped printing.
Hi and thank you for using fixya:
On this specific printer model this light means that your paper has jammed, you need paper, or your ink is low. Please re-start your computer and printer and try again. If problem persists check ink levels on the printer settings (computer)
Good luck
Apr 13, 2010 | HP DeskJet 932c InkJet Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
932c prints intermittantly
this is b coz of paper quality and sometimes due to moisture but try loosing the static and restart the system
May 07, 2009 | HP DeskJet 932c InkJet Printer
My printer jammed in the middle of a page and after I turned it off, pulled out the paper and turned it back mon its printing 1 line of jibberish and pushing out the rest of the page blank, page after...
Your printer queue still contains fragments of your print job
  1. Remove print job at your computer if listed
  2. Turn off printer
  3. Disconnect printer power supply
  4. Reconnect printer power supply
  5. Turn on printer
Your queue should be empty now.
May 05, 2009 | HP DeskJet 932c InkJet Printer
Middle orange light stays lit. Paper is not jammed.
The cartridge has a small electrical circuit board on it. That circuitry may be defective so that the printer does not recognize the cartridge. Return the cartridge as defective and try another. If that does not solve the problem, then discard the printer. I've read that most printers are manufactured to only last about three years.
Dec 29, 2008 | HP DeskJet 932c InkJet Printer
Hp 2200d laserjet
possiably bad gear assembly.
Sep 21, 2008 | HP LaserJet 2200D Printer
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
