Question about Canon SmartBase MP360 All-In-One InkJet Printer
Canon MP360 not printing black
New, genuine cartridge put in. Carefully wipied clean the removable carriage. Absolutely nothing showing up on paper. Don't know if colour would work or not as colour ink has been out for a long time.
  • mr_j_thornto Sep 05, 2009
    And that's supposed to help how?
My Canon Smartbase MP360 will not print and shows 'put in cartridge' which I have done and it makes no difference.
sometimes a little bit of dried ink stops the flow of ink
use a cue tip and genty clean both the puter contacts
and the cartridge contacts then try again
after resetting do the head cleaning tht the machine can do for itself
this work most of the time
hope it help ps watch and dont let any fuzz get left behind
Aug 22, 2012 | Canon SmartBase MP360 All-In-One InkJet...
I just installed new cartridges (3rd set) and printer still says ink is low. How can that be? Is there something I can do to reset the printer color and black buttons. They show yellow instead of green....
Hi
If you replaced the cartridges with genuine Canon cartridges then there's probably a build up of ink under the cartridge carriage. Pull out all the cartridges and lift up the carriage. Clean it using a non alcohol cleaner. While you're at it put some cleaner on a folded up paper towel and wipe the ink reservoir located on the right hand side, where the carriage sits when idle. If you replaced your Canon cartridges with off brand cartridges then you might not have changed the chips over. On the old cartridges there's a tiny chip glued to the plastic in front. This chip must be popped off and snapped onto the new cartridge. Good luck
Apr 06, 2010 | Canon PIXMA MP210 InkJet Printer
Canon Pixma MX700:one print cartridge not working
The cartridge is only a tank that holds ink. The printhead is the device that you put it into and probably has a blockage in the magenta head. Open the machine so the carriage moves to the center. remove all the cartridges.
TCT How to remove and clean Canon Printhead see the link below. The MX700 may have the locking mechanism at the front of the carriage, so you should move it slightly right and then pull the colour bar forward to release the printhead. carefully remove the printhead. Sit it in a shallow dish/tray of hot water for a few minutes and dry with a paper towel. Put it back in the printer reset the locking bar and cartridges. Try a nozzle check through the tools menu. Yoyu may need to repeat the process if the magenta printhead is badly blocked
Feb 13, 2018 | Canon PIXMA MX700 All-In-One InkJet...
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Jun 17, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Feb 13, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Mp 360
I had exaclty same problem - black not printing - was about to buy a new printer but did the following as a last resort about a month ago - remove the ink cartridges - removed the head and sat it on an a tissue - into the 'well' where the printer cartridges sit I dropped into there a very small amount of water as if to 'wash it through' where the ink would flow, (about a quarter tea spoon) - agitated it a bit - this flushed thru the gaps were the ink goes - I cleaned it all up - dried it with a tissue - put it all back together - it works fine now ! This was a last resort option for me but I guarantee it did work !
Oct 11, 2007 | Canon MultiPASS MP360 All-In-One InkJet...
Cannon smartbase MP360 inkjet printer
Looks like you are either using non genuine inks or have worn out the print head. Just replace the print head and use genuine ink, your print head will last longer and your colors truer. Non genuine ink is cheaper but the profit on it is huge, thats why lots of people sell it. Remember you get what you pay for.
May 20, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
119 people viewed this question
old marine
old marine
