Question about PC Chips M963GV (V3.3A) Motherboard
Bios system computer cannot at i want booting proses.although power is working and monitor is ready. even this problem at my friend wants to add VGA come motherboard is M963GV . i want do jumper bios as manual. can u help me to do it? i want u description this way... thank u!!
Nothing showing on display when powered on. i have tried everything i can, and i get no beep code. and is there any way to tell if the graphics card is dead?
First thing I would do is make sure it is powered on, make sure the VGA (or dvi) cord is firmly plugged in at each end. If so, and if you do not see anything at all when booting up, I would borrow a monitor from a friend or another computer. If it too does not work, then possibly the video card is faulty. It could, however, also be a bad power supply. Sometimes only part of the power supply goes bad, so some of the lights will come on but it does not boot up, or maybe not provide the power for the video card to work. If this is an add-on card, and if there is a VGA plug on the back of your computer, I would remove the video card and plug the monitor into the original VGA plug.
Dec 22, 2017 | Graphics Computers & Internet
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
E machine monitor not working. Replaced with newone. same results
There is no communication with the video card. Try re-seating the add-on card or checking BIOS for it to be enabled. You could also try adding a new card, and even testing the monitor on another computer. Lastly make sure the monitor is set to correct input like VGA or HDMI.
Jan 29, 2013 | E-Machines Computers & Internet
I cannot get my computer to recognize my dvi monitor
That is very weired, chose another type of conection with you videocard and monitor ex: hdmi cable if you have a hdmi output.
If not check the options of your monitor slow down the frequency to 60hz. I advise you to get another smal tft monitor from one of your friends to test may be thers a problem with your video card.
Hope this help
Jun 24, 2009 | Envision G22LWK 22" LCD Monitor
9600GT No Display
Have you put another power cable to the back of the Video card. There is a slot on the back of the GT for more power. Once that is plugged in beeps will stop and you should recieve signal
Feb 09, 2009 | ASUS PCI EXPRESS 2.0 GEFORCE 9600GT 512M...
Out of frequency LG500g
15"LG Studioworks500g Monitor Supports Up to 1024by768pixel resiolution.
First U can check UR system res is High and than Go to Enable VGA mode on ur system.
Sep 20, 2008 | Computers & Internet
After Power Out No Video (AT ALL) Upon Reboot
Plug a PCI VGA card into one of the PCI slots on your motherboard and connect your monitor signal cable to this add-on PCI VGA card and turn on your system . If your monitor shows the usual startup screen then you continue booting your comp and let the OS load , thereafter you BACKUP your DATA . Use a PCI VGA card from TRIDENT or S3 etc., so that your OS will use built drivers to display at 256 , 16 bit or 24 bit colour depth . These motherboards have problems around the GMCH or the Northbridge chip which has Graphics & Memory Control integrated . The refresh signal to your monitor does not indicate proper working of these GMCH . The memory of your comp needs attention and a check .
Apr 27, 2008 | MSI PM8M2-V Motherboard
No image on screen when boot up computer
check vga cable! check also video card on the pc!
Aug 16, 2007 | LG Flatron L1710S 17" LCD Monitor
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
PC Chips M963GV (V3.3A) Motherboard Logo
52 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
