Question about Nokia N70 Cellular Phone
Can i get pcb/main board of N70 as such my mobile set met an accident
    President:
  • 1,462 Answers
No you cant get the PCB seperately for the nokia phone, since the PCB involves integration of IC and micro porcessor, If your PCB is broken, its better to new phone
RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 14, 2009
My nokia n70 screen is sparking what i do to solve this problem
If there is some moisture or loose connection then you need to open the set to confirm.
If the indication is a light flicking then it can be due to faulty circuit of the backlight LED.
This can be due to cracked board, broken leads or PCB circuit breaks. Use a soldering station to do the touch up work.
Jul 27, 2011 | Nokia N70 Cellular Phone
Will record but no sound
hi you might has setup setting as a mute. please check at memu or setup setting. Good luck with you. If not, your micro mic or main pcb(printed circuit board) get defective. mostly the main pcb is the common. but it will alway depend on model of camera.
May 21, 2011 | Cameras
Just white screen cannot get thru with calls. tried software but in vain i was told you need to change the PCB which cost about 600 to 700 rs.. the set will function.. pl advise where i can purchase the...
Hai, In my country, we do not change the main board, because the cost is equal to the price of a new, why you need to buy the main board under the warranty repair only the longest one month? whereas if you buy a new or used, it is more worthwhile. If you have tried to change a new LCD display screen, but the results remain the same, perhaps it is divided UEM ic problem, this happens because you always fall. ic is too close to the frame. hentakkan effect on the frame due to falls, may interfere with the original position, if the worst Solder balls under the ic off. If you are lucky. Try to heat the surface of the UEM ic, add Solder flux before the process is done. Solder balls when you get looked melted, press the top surface is a soft ic so it does not directly close to the surface of the board, as this can make Solder ball attached to one another, if you have a place to sell spare parts for ic, it is better there ic change is the new home you buy a new board. cheaper cost, but I do not know the cost of installation if you sending to your technician.
Aug 06, 2010 | Nokia N70 Cellular Phone
The screen on my EOS 350D no longer works. I cannot change the settings or view pictures, but the viewfinder is working fine.
Either your Lcd contact which connected to main pcb is come out from board or LCD is burnt out.
could be main pcb not giving signle to back cover. you need to relaced main pcb or LCD.
Aug 04, 2010 | Canon Rebel XT / EOS 350D Digital Camera
White screen display on Nokia N70
Good day sir/maam, the white screen problem is a serious one. problem on the main board, decide first if you want to fix it yourself or not? if yes there are several hot fixes you may need to do and that involves using(buying) a hot air gun. the technique is resoldering all main IC circuits on the mobile phone and pray that the circuits are in good order. If not, better bring it to a service center.
Sep 10, 2009 | Nokia N70 Cellular Phone
Nokia n70 display is white,
hi murthykr
may I ask, although the display is white can you still hear a tone? Or if you restart your phone you still hear a tone.
If yes..maybe the connector that conects your lcd to the main board is lossen. it happens when the phone is accidentally drop. If you know how to open your phone, try to tighten all the screws inside and start.if nothing happens. Try to replace your lcd with a new one.
OR
Consult your dealer for posible factory defect. ^_^
hope this will help you
Dec 24, 2008 | Nokia N70 Cellular Phone
N70
hi
if you download the themes from net so there is a option comes with these animation themes press the main menu and look at the bottom you will find the folder name skin settings there you will be set your animation
thanks
your friend
Oct 20, 2008 | Nokia N70 Cellular Phone
Ear phone sign on my mobile gets activated
uour head phone jack in mobile is damaed just go for repair
Mar 21, 2008 | Nokia N70 Cellular Phone
Problem with the speaker in z550i
good day, first check your settings, if your phone settings is fine, i suggest that you bring your cellphone to your nearest service center thanks
Feb 17, 2008 | Sony Ericsson Z550i Cellular Phone
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
Nokia N70 Cellular Phone Logo
293 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
