Question about Technics Audio Players & Recorders
I have a technics av control receiver sa dx1050. I have two digital audio inputs for 5.1, one for the cable box and the other for my xbox 360. The sound is going crazy - its super loud, breaks up, and will be extremely loud, right up untill I turn the volume off. My stero settings arent effected at all, just digital input. I unplugged the reciever, no good. I change the audio settings, still not good. I have never have this happen untill about 2 weeks ago. Do I need a new reciever? Ii has to be the digital audio, but how do you fix that?
  • rs8684 Sep 05, 2009
    Ok, the sound is back to working now. I cleaned the unit. But if it blows out again, I am going to try to do what you suggest. How in the heck would i check for a loose wire, or the voltage on the capacitors? If that's the case, then I guess I am buying a new reciever.
    Ok, its back to not working. All the conections were fine, so I am about to dissasemble the unit. I'll spend a little time trying to fix it, but I already started pricing out new recievers at best buy. Thanks for the help.
    Rick Snyder
    Brigadier General:
  • 8,619 Answers
Hi
You need to check all the connections if they are properly connected then the issue is any internal wire going loose or is burned. Also this can happen due to a blown fuse inside the receiver. Please open the unit and check the voltages of the capacitors on the sound board. If its a old Panasonic receiver and you are looking to buy a new one then please check this link.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 05, 2009
  • Rylee Smith
    Rylee Smith Sep 05, 2009
    As its working now then its great however if the same issue happens then you can open the unit and check all the wires and capacitors. You can also check what FixYa recommends from this link.
    Thanks
    Rylee
  • Rylee Smith
    Hi Rick
    Thanks for using FixYa. Please remember to turn off the power supply before diassembling and also check for any burnt component or loose soldered component. You can find the recommendations from the customers who have bought the products at this link--
    Fixya Recommendations
    Thanks
    Rylee
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    Can i hook up my technics sa-g76 to my tv
    yes, using the the rca outs of your tv, and they will connect to an input on your reciever that may already be marked for a tv, or cable box
    Jul 28, 2013 | Panasonic Technics SA-G76 AV Control...
    Technics sa-dx1050 overload
    if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
    Jul 23, 2012 | Technics SA-DX1050 Receiver
    Not getting true surround sound
    The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
    To configure your audio settings, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox Dashboard, select Console Settings.
    3. In the Console Settings area, select Audio.
    4. In the Audio Settings area, configure settings for analog output or digital output:
      • Analog output settings:
        • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
        • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
      • Digital output settings:
        • Digital Stereo: Select this setting to use digital stereo output.
        • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
        • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
    Note You must use one of the following cables to support digital output:
    • Xbox 360 Component HD AV Cable
    • VGA HD AV cable
    • S-video AV cable
    • Advanced SCART AV cable
    • Japanese HDAV D-connector AV cable
    Additional info:
    http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
    Sep 28, 2009 | Audio Players & Recorders
    I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
    1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
    2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
    electech
    Nov 26, 2008 | Technics SA-TX50 Receiver
    XBOX 360
    How to Connect XBOX 360
    This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
    This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
    This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
    If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
    Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
    Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
    If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
    Now you are ready to play.
    Sep 06, 2008 | Microsoft Xbox 360 Console
    Not working
    Operationg instructions says it is "F 70". When it appears it says to turn the unit off, disconnect the aC power supply cord, then reconnect and turn theunit on. Consult your dealer if "F-70" remains on the display.
    Mar 30, 2008 | Technics SA-DX1050 Receiver
    Technics surround sound system
    Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
    Dec 29, 2007 | Technics SA-DX1050 Receiver
    Hook up your Xbox to a Dolby Digital Decoder
    Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
    Nov 20, 2005 | Microsoft Xbox 360 Console
    16 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    T-Comtech Repairs
    T-Comtech Repairs
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
