Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Legend 2 pool cleaner auto back-up feature stopped working
Auto back-up feature will not pull cleaner out of corner when it gets stuck
  • 128 Answers
Make sure you have a clean filter and clean wall fitting screen. Pull hose out of water and lay it so you can watch the back-up mode go through its mode. The housing might be crack and have a leak which might not give the valve enough power.
Posted on Sep 05, 2009
Stuck in corner
sounds like back up valve isnt working that is the rectangular object above the cleaner
Jun 13, 2013 | Pentair White/Gray Legend Platinum...
Pentair legend pool cleaner gets stuck
make sure back up valve is working if not replace
Feb 07, 2013 | Pentair White/Gray Legend Platinum...
How to take apart a legend platinum pool cleaner
take off hose and ball then turn upside down remove 4 screws on 4 corners then top comes off
Jun 28, 2012 | Pentair White/Gray Legend Platinum...
Pentair Platinum Legend gets stuck between my bar stools and the wall
This question is a little vague. You have bar stools in your pool? If so, you should remove them before cleaning. If you are using this pool cleaner outside of the pool, you are using it improperly and probably ruining it.
Oct 24, 2010 | Pentair White/Gray Legend Platinum...
Zodiac G2 gets stuck at far end of pool in two corners. Each time I have to pull the hose to get it out, then its fine. Anything I can do to stopit getting stuck in the first place, please?
The biggest cause of this is current in the pool driving the cleaner to the corners. You propally just need to change the direction of the eye balls on you returns to the pool. Face them down the pool wall or just in another direction to break up the flow of water in the pool.
Oct 07, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My wheels wont move
Check to make sure that you do not have a blocked impeller. I would also check to make sure that you dont have something stuck in your drive train. The only other thing that could cause an issue with these pool cleaners is if you are not getting sufficient water flow.
May 07, 2010 | Pentair White/Gray Legend Platinum...
Not BACKING UP
The valve is called a back up valve but that jet of water just hauls the cleaner out of corners, but the unit itself dosen't back up.
Oct 14, 2009 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Nav gets stuck on steps and wont back out of a corner
Try adding a hose or turning the return jets in different directions. If it is short on hose it will pull up from pool serface and won't get enough drive to pull itself out of the step. Returns will get a current going in thr pool and can sometimes push the cleaner wher it wants it to go usualy the steps will provide a good stopping point, like a boat getting caught below a waterfall in a river. If this is the problem the cleaner will run good for the first hour or so after the pool first starts. hope this helps, good luck.
Sep 29, 2009 | Hayward Navigator Pool Cleaner
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
330 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
