Question about Imperial IFS40 Deep Fryer
Pilot on IFS-40 BUT WHEN THERMOSTAT TURN on pilot lights off , what is problem?
  • 430 Answers
Check the vent hole (plastic plug, not the screw) on the regulator between your gas line & the back of the fryer. If it is plugged, it wont fire & the pilot will go out when thermo-stat makes up to turn on.
Thank you.
Posted on Sep 05, 2009
Pilot goes out after fryer reaches operating temp. Replaced milli-volt generator already.
sometimes the hole in the pilot tube gets dirty and needs cleaned in the old days the gas man had a tiny drill bit he reamed it with .
Mar 05, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Hello,I have a Imperial IFS deep fryer S#06301407 .We had a pinhole repaired in tank.I know that tank was removed prior to repair .Unit did work fine other than leak before tank repair.After lighting pilot...
You can use a jumper wire to test the valve. The voltage is LESS than 1 volt so do not worry. Imperial fryers usually use a robershaw gas valve. the 2 outside terminals...left and right.... are where the thermostat connects. Using a jumper wire after the pilot is lit will tell you if the valve is good or if it's the thermostat. You can also use a multimeter and check the continuity of the thermostat.
Tom
Jun 08, 2010 | Imperial IFS40 Deep Fryer
Brunners will not light on my imperial IFS-40
WTF your pilot light might be out RUN LIKE HELL- air the place out then go back and re-light it.
Aug 25, 2009 | Imperial IFS40 Deep Fryer
Pilot wont stay lit on my Imperial IFS 40 deep fryer
Hello. It sounds like your wiring is shorting or crossed for sure, or your gas valve has failed, but the pilot lights, and stays on, so good sign. If you hosed the hi-limit or the thermostat, these could short internally, and cause the pilot to drop out. Try this, disconnect the wiring going to the hi-limit ( control with the 3 screws ), and the thermostat, relight the pilot with only the thermopile connected to the gas valve, turn it to on, and see, if it stays, then a wiring problem, or component problem for sure. I see I cannot get a diagram from them, maybe you can call, and have them send you one. Let me know.
Hope that helped, and thank you.
If you need more help, "ask me",
Mar 31, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Imperial IFS40 Deep Fryer Logo
74 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
paulcarew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
