Question about Cycling
Hi i purchased a diora diamondback ladies roadbike 12 months ago and it is starting to rust where the headstem meets the forks. is this a problem with this bike? it is kept inside in my laundry with my trek carbon bike and are always cleaned after all rides .also some of the fittings are showing bad signs of rust. frame is fine and so are the wheels. love riding this bike but disappointed with the rust bubbling under the paint work. it is quite visible.i am worried that it will weaken the bike headstem maybe causing me to crash.hoping you can help. i purchased the bike at standish westlakes s.a. in july paying $539 for it
    Scholar:
  • 104 Answers
  • The rust is only superficial and will in no way weaken the bike stucturally so dont worry about the frame being weaked. When the frame was painted there may have been a residue from the manufacturing process that was not removed prior to painting and this hashi i purchased a diora diamondback ladies roadbike - spellcheck.gif resulted in the weakness in the paint. If you are worried about it you could scrape back the rust spots and touch them up with a little primer then a dab of gloss. You can buy small ammounts of paint from a model shop or use metalic nail polish if a metalic finish. An alternative is to treat the spots with rust converter and spray the bad areas with WD40 and this should should protect it.
Posted on Sep 05, 2009
How to reassemble diamondback outlook forks
Hi, Hugh for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Diamondback, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.diamondback.com/Data/Sites/12/media/support-owners-manuals/2012_om_diamondback.pdf
Fix Five Common Repairs
Diamondback Tech Fork Sag setup
Replacing Forks Shocks On Mountain Bike
Jul 20, 2016 | Motorcycles
Bike squeeks from front suspension
put a couple drops of oil on the stanchion tubes of the shock forks where they seals connect with the sliders and see if that helps. It is possible that inside the fork it has dried out and the spring needs some grease where it seats inside of the fork.
Jun 25, 2014 | Diamondback Edgewood LX 700c Men's Hybrid...
How can a kickstand be mounted on a Diamondback Recoil?
Hi larryaw...
You can purchase the type of kickstand that bolts to the real axle and use it for your primary kickstand.
Please take time to rate me
http://www.amazon.com/Rear-Mount-Kickstand-Bikes-Chrome/dp/B001HBLEM4
Jul 27, 2011 | Diamondback Recoil Comp Full Suspension...
Fort Adjustment
Check the top of one of the forks, there may be a knob type dial that you can turn clock-wise or anti-clock-wise, turning it one way will give you a stiffer ride, turning it the other will give you a softer ride. Some forks don't have this pre-load adjustment however.
Cheers.
Jul 09, 2010 | Diamondback Response 26 Men's Front...
Blurred,double image
These should still be well within warranty.. If you still have proof of purchase that will show the date which should be enough for the shop to honour the warranty.
Bushnell's warranty is 12 months everywhere..
Dec 14, 2008 | Bushnell Excursion Binoculars
Bicycle Fork Installation
remove front wheel
undo allen screw or bolt securing headstem to fork
remove headstem and handlebars
undo lock nut & ring retaining bearings, at top of fork tube, do not lose bearings which may be loose.
withdraw fork from fork tube, do not lose upper bearing race
remove lower bearing from old fork
install lower bearing on new fork (I prefer replacing bearings)
remove brake caliper from old fork install on new fork
insert fork in fork tube
install upper bearing (I prefer replacing bearings)
install retaining ring and lock nut on fork tube, adust untill there is no wobble, but free movement, too tight the bearings will collapse too loose the rider will fall off
tighten lock nut
install headstem
tighten headstem allen key - bolt
install front wheel
Oct 29, 2008 | Marzocchi 2008 XC 700 ATA Mountain Bike...
Coleman powermate 5000 gen.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clen the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | Coleman Powermate Powermate 5000W...
Cycling Logo
188 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
