Question about ASUS P4P800-VM Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
When i try to power on my computer i get 2 very quick beeps followed by 6 additional short beeps from the case speaker. It sounds like the HDD is spinning and everything has power, but nothing happens, nothing on the monitor...
  • michael_l923
    michael_l923 Oct 21, 2013
    Same with the P4SD-LA (COBRA) mb on a HP Compaq Presario SR1034NX - It turns out it was the PS2 connector that was unseated that appears to fail the keyboard test in the POST!
  • michael_l923
    I DID experience this symptom at least one other time, and I thought it had to do with failed memory, so I cleaned dust debri from the tower and reseated the memory - inevitably, disconnecting and reconnecting all of the connectors including the PS2 keyboard connector! The description of two quick, short beeps with then six short beeps appears to be more accurate than me saying two short and six long!
  • 103 Answers
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Posted on Sep 05, 2009
SOURCE:
I have my rest and power hooked up in the right plugs but nothing is happening only thing comes on is the light to the motherboard when plugging the power from the computer case to the motherboard the...
Hello
You may have the reboot or restart wires backwards.Or on the wrong pins on the motherboard.
Here is a link to your mobo. Shows correct hook up.
Also be sure your memory sticks are in proper slots.If you have 2 they need to be seperated.
One in one channel the other in the second channel slot.Usually the slots are color coded.
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Aug 09, 2011 | ASUS P4P800-VM Motherboard
I downloaded the audio drivers for my p4p800-vm asus motherboard .....says there are no conflicts but i still cant hear any sounds....speakers are working properly and nothing is muted
Play some music then get some headphone and try the audio ports with a green ring. See photo
http://atr.k12.hi.us/tutorials/tutorials/sound/images/ssintegrated.jpg
Sometime the audio is only working via the audio ports located on the front of the computer case. Other times it only works via the audio ports on the back of the case where all the connectors are located.
Feb 28, 2011 | ASUS P4P800-VM Motherboard
Saya pake mb p4p800vm, tapi vga driver tidak terdeteksi
http://www.driverstock.com/ASUS-P4P800-VM-driver-download/6-9-10025/index.html
Oct 14, 2010 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
Hi, i'm trying to install motherboard driver LAN, but only drivers i find is the one with the 'PROUnstl' file? I need to install, not uninstall
Open the link provided by Asus below;
http://support.asus.com/download/download.aspx?modelname=P4P800-VM&SLanguage=en-us
Choose your current operating system from the drop-down menu.
Click the + sign next to LAN to open. Download your LAN driver.
Please check your bios. See page 2-18 in your manual. Make sure your Onboard Lan is set to [Enabled]. Save and exit the bios.
Your system with auto restart. Check windows update service.
Need your manual? http://dlsvr04.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Cheers'
Mike
Aug 09, 2010 | ASUS P4P800-VM Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
Power led connector problem
[ 1] [ 2] [ 3] [ 4] [ 5][ 6][ 7][ 8][ 9][10]
[11][12][13][14][15]16][17][18[19][20]
Robert,
Above is a rough diagram of the Front panel connector on your Motherboard. Your Power LED should connect to pins 1 & 3 if this connection does not have the power LED come on with the PC then reverse which wire you've attached to those two pins. (As LED's are polarized they must have current flow in one particular direction to operate) Pins 11 & 12 are your Hard drive activity connector
Hope this helps you
Dave
Nov 11, 2008 | ASUS P4P800-VM Motherboard
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
ASUS P4P800-VM Motherboard Logo
725 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
