Question about Lexmark X5470 All-In-One InkJet Printer
Lxctafcn.dll Device Moniter Request Then adifferant number eash time.
Need: ENUM slbcp.dll sccbase.dll gpkcsp.dll to install Hp 1410
Access the manufacturer's web-site: http://support.hp.com
and enter the model-number, and do the search.
You'll find the device-drivers available for download for your All-In-One.
Download.
Install.
Print a test-page.
May 22, 2011 | HP PSC 1410 All-In-One InkJet Printer
Error 401
SYMPTOMS
Internet Explorer may not post data from a POST request and you may receive a "Page cannot be displayed" error message. This problem may occur if the following conditions exist:
  • You perform the POST request on a new connection with a target page that requires authentication.
  • The server immediately replies to the POST request with a "401 Access Denied" response and closes the connection.
CAUSE
The server closes the connection without reading the whole request body, and the server resets the connection when it receives frames that involve the entity body for the POST request. Because the connection is reset, Internet Explorer (Wininet.dll) cannot read the "401 Access Denied" response and process it.
RESOLUTION
A supported hotfix is available from Microsoft. However, this hotfix is intended to correct only the problem that is described in this article. Apply this hotfix only to systems that are experiencing this specific problem. This hotfix might receive additional testing. Therefore, if you are not severely affected by this problem, we recommend that you wait for the next software update that contains this hotfix.
If the hotfix is available for download, there is a "Hotfix download available" section at the top of this Knowledge Base article. If this section does not appear, contact Microsoft Customer Service and Support to obtain the hotfix.
Note If additional issues occur or if any troubleshooting is required, you might have to create a separate service request. The usual support costs will apply to additional support questions and issues that do not qualify for this specific hotfix. For a complete list of Microsoft Customer Service and Support telephone numbers or to create a separate service request, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/?ws=support (http://support.microsoft.com/contactus/?ws=support) Note The "Hotfix download available" form displays the languages for which the hotfix is available. If you do not see your language, it is because a hotfix is not available for that language. The English version of this fix has the file attributes (or later) that are listed in the following table. The dates and times for these files are listed in coordinated universal time (UTC). When you view the file information, it is converted to local time. To find the difference between UTC and local time, use the Time Zone tab in the Date and Time tool in Control Panel.
Date Time Version Size File name ------------------------------------------------------- 27-May-2003 14:57 6.0.2800.1204 586,752 Wininet.dll
Jan 24, 2011 | Computers & Internet
Unable to install it says "A required .DLL file, USERENV.DLL, was not found"
Try uninstalling anything that may have got installed from the installation. Also make sure you have the most upto date software from dlink.com. You can also get firmware updates there for the device as well. Just enter the model number and look for the drivers for that device.
Oct 21, 2010 | D-Link WNA-2330 Notebook Adapter
My computer says I'm missing esapp.dll & ltdis10n.dll. How do I fix that?
This may be due some or all of the following reason: Corrupt file-system, corrupt registry entry, improper/incomplete device driver installation or software installation or may be due to a virus infection.
Make sure you have a backup of important files/photos/documents in your system.
Try repairing you file-system using check disk utility that comes with windows. Repair your registry using a registry tool. Update the device driver or the application. esapp.dll & ltdis10n.dll belongs to Kodak Easy Share application. First completely remove the application and try reinstalling it. Have a full system virus scan with latest virus definition update.
Update your windows system with current patches and fixes using Windows Update utility.
All the best
Mar 06, 2010 | HP Computers & Internet
Error loading C:\PROGRA~1\MYWEB~\bar\3.bin\M3PLUGIN.DLL
Sep 18, 2009 | Intel Motherboard
Urlmon.dll not found whith device manager
The URLMON.dll is a system file , that might have got corrupted . You can download the same from the link below
http://www.dll-files.com/dllindex/dll-files.shtml?urlmon
Save the file on the desktop and then extract the file to the following location
c:\windows>system32 folder
If the same doesnot fix the issue , check by restarting the system in safe mode. Restart your computer and before windows begins to load tap the f8 key multiple times , till you see the safe mode option on the screen . Login as the administartor and check if you are able to open device manager . If yes , then just create a new user account the problem would be resolved
thanks
Proton
Jan 10, 2009 | Computers & Internet
TV Screen is to dark when playing games or watching movies
turn off enegery saving mode cheak coler britness lock it into your fav user settings on all inputs eash input hdmi has it own coler u must adjust ok to fit needs on eash input k
Oct 08, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Help about driver and softwera
which monitor you are using ...?
you mean you need the graphics driver or the monitor driver itself reply clearly i will get you the links...
and also tell me the model of the monitor if it is monitor driver & motherboard details if it is graphics driver ....
i am always here to assist you ..
reply me soon
Apr 07, 2008 | Mitsubishi Diamond Pro 900U 19" CRT...
Lexmark X5470 All-In-One InkJet Printer Logo
290 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
