Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Also getting the LO code. How do I access the switches to flip?
I'm not sure how to get to the pressure and temp switches to try to flip them one at a time, as suggested.
    Champion:
  • 246 Answers
Clean the filter
Posted on Sep 11, 2009
How to check a bad pressure switch
make sure filters are clean make sure voltage on both sides of pressure switch if not check copper syphon loop to see if plugged
Oct 03, 2014 | Pool & Spa
Getting a code of "LO" on my colman spa
lo pressure either dirty filters or recirculation pump isnt working or working properly or the pressure switch is bad or syphon loop to pressure switch is plugged
Sep 24, 2014 | Pool & Spa
Main pool pump failed and replaced. After replacement H400 heater shows LO code. Is there a reset capability on the heater?
LO code is for a fault at 1 or more of 4 switches. water temp, pressure limiter, ect. It is recommended that you contact a pool professional to deal with something like this. If you are in the Phoenix Metro area you can contact me at info@wefixuglypools.com
Dec 25, 2010 | Hayward H Series Pool & Spa Heater 400k...
Getting LO error
Lo is an error code dealing with the safety loop, hi limit switches, water pressure switches. Check for continuity and the wiring between the hi limit switches and the water pressure switch. Also, check to make sure the filter is clean and the pump basket is empty. These also can cause a low flow situation that will cause the pressure switch to not close properly.
May 23, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Gettin LO error on display
May 23, 2010 | Hayward H-series Electronic Gas Pool...
My hayward heater gives a LO error when trying to heat. you cant put the heater either in pool or spa mode, then set the temp. The temp flashes then you get a LO error. I've checked the valve settings to...
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Feb 15, 2010 | Hayward H Series Pool & Spa Heater 400k...
Error code lo and eo4
The LO is just telling you the water is below 58 degrees. The EO4 is the fan sensor. If you haven't used the heater for a while you should check for rat and bird nests then you can check your air pressure switch to be sure it is OK. The NT LN model will have the gas pressure switch in the same circut, so if you have the low nox model be sure to check all your gas valves and be sure they are on. If this is a LP heater be sure your tank is at least 1/3 full to have enough pressure to run the heater. If the heater hasen't been run for a while be sure to bleed your gas line also. Good luck.
Dec 04, 2009 | Pentair Minimax NT Heater
LO service message
LO is ignition lockout. The heater has tried to fire three times without success. It is usually the prressure switch but can also be the temp limit switch or the vent pressure switch. Locate and jump one at a time to find faulty switch.
Aug 15, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H250 giving me a "LO" error code and does not turn on.
9 times out of ten this means that you have a faulty water pressure switch. It could also be a limit switch, or air pressure switch. Make sure the filter is cleaned, and all valves are in the correct position. Once you are CERTAIN that water is flowing through the heater, you will need to short each individual component to find the faulty one.
Apr 10, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H400 heater problem
LO usually indicates low water pressure. Check the pressure in your filter. You may need to backwash. If the filter is to clogged then the water pressure in the heater is so low that it won't activate the pressure switch. While checking the pressure turn the pump off and then on to make sure the pressure gauge is actually working. Also check the pressure coming out of the inlets into the pool. You should be able to tell if you have sufficient water pressure.
Jan 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
62 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
