Question about Pioneer HTD520(R) System
Won't turn on
When I try and turn my system on it turns straight back off. how can i fix it.
    Problem Solver:
  • 9 Answers
Sullo.
Try to unplug your system for 5 mins and plug it back into the wall. Also if there is a reset button or hole behind the player try sticking a paper clip in that hole while it is still plugged into the wall until the power light goes red or off.
These should reset things on your system
Cableguy
Posted on Dec 11, 2007
I went to start my car and I cant turn the key. now my shifter wont move either. please help I have no idea what is wrong
Try to turn the key while moving the steering wheel. Sometimes the problem is in the lock system of the steering wheel.
Here you have several youtube tutorial where a "can't turn key" problem is solved:
Key won turn How to fix car truck or van ignition lock when can turn wheel...
How to fix ignition key that doesn turn Opel
How to unlock your steering wheel
Ignition Won Turn Key Several Reason Why This Happens EZ Auto Remote
You can find more tips searching in google for
start car can't turn key
Jul 30, 2015 | Saab 1998 900 SE
Won,t shift out of park?
Check to see if you have brake lights if not fix the switch on brake pedal. If yes you need to look at the shift interlock system, normally a little white box just below the key on the column. On fords you can put key in and turn a little bit so it's straight vertical and shift to neutral then start it. Your problem is with the shift interlock system that gets activated with the press of brake pedal
Jun 13, 2014 | 1997 Ford Ranger SuperCab
My kyocera rise mobile connection turned off 4 hrs and kept turning off and on and now it won't receive or make text or calls I even tried turning it off and back on and taking the battery out 25 mins...
This seems most like the power key is tripped and haven't back to it's own place. Try to push the button let it rebound back. Else if there is a problem about the system, please try to use Restore Factory Settings to fix it, If anything can help you, I'm very pleased.
May 26, 2013 | Cell Phones
My ps3 wireless controller will turn off my ps3 console. Why won't the controller turn on the ps3 console?
Try to resync the controller. With the system off, plug in the usb charging cord. then turn the system on. Use a pin to click the reset on the back of the controller. It should flash a number of times. Then it will stay on #1. It might take care of it. Good luck.
Apr 18, 2013 | Sony Playstation 3 (PS3) Console
Troy Bilt Lawn Tractor won't turn left - still turns right
hi, mam i want to solve this prolem try contact or text this number 0927642929 / ( 032) 5127262
Sep 11, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
I have a Windows CE Sylvania netbook that won't boot to the desktop. I can turn it on, but it seems to freeze right as it turns on. It shows the start up screen where it says "Loading OS Image...
One temporary solution is to remove the battery for a while until all the capacitors in the unit discharge. Upon replacing the battery, you get one good power up try. Notice that the date and time have reset. Once you turn off the unit and try to power it up again, the problem comes back and you must again remove the battery for a while. There may be a patch to fix the boot loader, but I have not found it yet.
Jun 15, 2011 | Computers & Internet
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Pioneer HTD520(R) System Logo
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
