Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I cant print coloured text from microsoft works
My colour text comes out with a shadow (in a different colour) like something is out of line. Black text prints crisp and clean.
yes, it is something of line. Color text is printed by three cartridges overlapping on the page. Most printer have a setting called Calibrate. You can sometimes do it in Windows, too.
Start button--> Control panel-->devices and printers--> (right click the name of the printer--> properties--> the last tab often is calibrate.
Sep 26, 2016 | Office Equipment & Supplies
I cant seem to print text. i can only print graphics. i recently put in new ink cartridges, tried to print a page of only text and the pages were blank. tried to print another page with text and graphics,...
Have you tried printing text in different colour if that works the black jets are blocked- try running the cleaning cycle to clear (it may not use black ink in graphics)
Nov 15, 2010 | Brother DCP 130C All-In-One InkJet Printer
How to print when one color is empty
you will change the colour of the text you want to print to the colour of the remaining colour then it will print with the remaining colour.........if it is red you will change the colour of your text to red and if it is green you do the same.....!
Jan 21, 2010 | Brother MFC 210C All-In-One InkJet Printer
How to print text using red or blue ink
I would just set the text color to red or blue in your document.
Depending on the program that you use it could have different steps.
Here is steps in Word:
You can change the Colour of your text by highlighting the text and then clicking on the 'A' symbol on the toolbar. This will change your text to the Colour which is underneath the symbol 'A' on the toolbar. To change the Colour, click on the arrow next to the symbol and select one of the colours from the small box which appears. This will change the Colour of your text as soon as you click on the Colour.
Another way of changing the Colour of your text is to go to 'Format' and then click on 'Font'. The font window should appear. Select a Colour from the 'Colour' section. You can see a preview of what the text will look like in the box below. You can also add various effects to your text by using the options in the 'Effects' section. This will also allow you to see a preview in the box at the bottom of the window.
Hope this helps. Please remember to rate this information.
May 03, 2009 | Office Equipment & Supplies
The printer, will scan, and the printer will print test copies, showing that it has colour in the cartridges, however when printing text off microsoft word, the page goes through the printer and comes out...
Go to the printer specifications from the word program print window, check the "colour" settings, if colour printing is not marked, then mark it and your problem may be solved ...
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Printing problems
I'm sure a gremlin fixed it, because I have no idea....
Jul 30, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
RICOH AFICIO AP3800C
This normally suggests to the transfer belt it is possibly worn and the transfer unit will need replacing
Hope to be some hep
Jan 02, 2008 | Ricoh Aficio AP3800C Laser Printer
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
19 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
