Question about Kenmore 63942 Dryer
My dryer runs but has no hot air and won't turn itself off.
It is an inglis, old, but has stopped blowing any hot air, and does not turn off on it's own. Can you help me please. I really can't afford a new one.
  • 74 Answers
You might need to replace the heating element
Posted on Sep 05, 2009
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Dryer is only 3 months old and is not drying clothes... why? technician came out twice and said dryer is up to 130 degrees but clothes are still not drying.
first make sure your vents are not clogged, inside and outside your home,, if they are free make sure the vent hose is not kinked when the unit is pushed back,, if all is good take the vent off the back and turn it on and make sure it is blowing air out while it is running
Jan 20, 2011 | Whirlpool Inglis IP8200 Dryer
Washer Front Panel states: 70 Series Heavy Duty Plus Dryer Label inside door says: Model / Stock No 87980100 79801 Ser No M94039293. Dryer Issue: Drum Turns, Clothes get hot, Lint screen clean, 1.5 ft Exh...
Possible blower fan failure, Or Blower fan blades are choked with lint, so no blow.
Your gonna need to open it up. If fan blades are choked, simply clean and vacuum them. Reassemble and test run.
If fan blades are clear, (minor lint-ing will not stop it working) then it indicates fan motor is bad.
Possibly a capacitor (motor starter) rather than motor. Usually a small cylindrical object with wires attached, located in close proximity with related motor. Check for swelling, leaking. if looks OK it's likely fine.
Capacitor is cheap to replace first. Must use SAME VALUES as original.
Nov 17, 2010 | Kenmore Dryers
AEG 57700 only blowing cold air, heater not working
CHECK VOLTAGE=240VOLTS NOT 120VOLTS,ITS TAKES 240V TO HEAT BUT WILL RUN ON 120V.
THEN START WITH HEATER ELEMENT ..SEE IT ELEMENT IS OPEN.
THEN START RUN ING TEST ON THERMO'S TO SEE IF CLOSED OR OPEN...
THANKS FREDDY
Feb 14, 2010 | AEG T57800 Electric Dryer
Dryer blows air, but no heat - the dryer powers on, the drums turns and the fan blows air, but the air isn't hot.
There is one of two possibilities:
1.-The heating elements dont come on due to a wire burnt off or the element itself has burnt out.
2.- There is a small electronic device in the element circuit called a thermal overload switch, which has and often does malfunction, stopping the power to the elements.
Best wishes,
Graemevm
Dec 17, 2009 | Office Equipment & Supplies
OUR KENMORE DRYER BLOWS OUT COLD AIR
It's most likely a thermal fuse if it's a gas dryer. very easy to install. If your dryer is electric, it's either the thermal cut-off or the heating element itself. If you need help with anything, please feel free to e-mail me. good luck :)
Jul 06, 2009 | Kenmore Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Sep 16, 2008 | Dryers
Kenmore 63942 Dryer Logo
121 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
