Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
The pull cord has come off the spindle, how do I get it back on properly or install a new one and reset the spring tension
    President:
  • 2,220 Answers
Remove the starter cover, rewind or wind a new cord onto the spool. Turn the spool about 2 turns against the spring, thread the pull cord through the starter cover and reinstall the pull handle.
Lou
Posted on Sep 05, 2009
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
How to restring mower
Making the assumption that you are asking how to replace the pull cord on a recoil starter on a vertical power mower engine...??
You must remove the plastic cover in some cases, and the shroud over the top of the engine to gain access to the gizzards of the recoil starter.
That also means in most cases loosening and removing cylinder head bolts, and you MUST use a torque wrench to replace them to the proper tightness, so be prepared.
Once you have the shroud removed, on the underside will be a round reel that is retained by several bent over tabs. You have to straighten at least two of the tabs, and then you can remove the cord reel.
BE CAREFUL, as there is a flat spring inside that will jump out and possibly injure you.
You have to get the correct cord, string it through the handle in place of the old, cut it to the proper length, feed it back through the shroud, and wind it on the reel. Then you have to pre-tension the spring so that the cord will retract after you pull on it.
Once you have the cord routed and fastened to the reel, and captured on the pull handle, you can wind up the spring.
Unless you are VERY handy and have strong hands, I would not recommend you do the repair yourself. The spring must be tensioned, and held in place. It does not want to stay, and will jump out easily.
If you get it tensioned, the cord in place, then the reel must be put back into the shroud and the tabs bent back in place. Then the shroud has to be re-installed on the top of the engine, and the bolts tightened properly.tom
Jun 18, 2012 | Yard Machines Garden
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
The pull rope will not rewind. How do I reset it?
The cord should be removed from the spool entirely, then wind the spool spring CCW for a number of turns making sure the spool can be turned for about 6 turns more (during start). Wedge the spool so that it can't unwind the spring again. If the old cord was about worn out, replace it with fresh. Melt the cord end somewhat so that the knot won't pull out, then tie an overhand knot in the cord end. Feed it into the inner retainer on the spool, then thread the cord around the spool 5 or 6 times in a CCW direction. Once wound, feed the loose end out of the cord port, slide the pull handle on, melt the cord end, and tie an overhand knot on it. Stuff the knot into the handle and release the wedge from the spool so that spring tension pulls the cord tight. Pull the cord out several times to make sure nothing interferes with cord and mechanism, then install on the saw and check the start operation. The spring should never bind-up when the cord is fully extended. Hope this helps!
Jul 25, 2010 | McCulloch Garden
How do i get the pull cord spring back in on a
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Nov 22, 2009 | McCulloch Garden
I need to install a new spring for the pull start in my poulan 220 pro chainsaw
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Nov 01, 2009 | Poulan Garden
My recoil inside the pullstart
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Jun 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
May 23, 2009 | Mantis Little Wonder Tiller/Cultivator...
Broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18 Inch replace starter spring?
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
154 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
