Question about Logitech Cordless Mouse
Mouse not working. changed batteries, pushed connect buttons, checked leads, light on bottom of mouse =- help
    President:
  • 1,564 Answers
Reinstall your software with the install disk, if tha doesn't work, remove the ball from the bottom and take your little sisters toothbrush(just kidding) and clean the opticle points with it. There should be four of them. Good luck.
Posted on Sep 06, 2009
How do I connect my Logitech wireless mouse to my computer
I use Logitech wireless mice and so does my wife. After a battery change you have to reconnect the mouse with the wireless receiver
. First push the button on the receiver, then push the button on the bottom of the mouse. It should connect and you will be ready to go. If this doesn't get the mouse working, you may have to unplug the mouse, then plug it back in the USB port, then reconnect to the receiver. Hope that helps.
Sep 30, 2014 | Logitech Cordless Mouse
My wireless mouse stopped working; I changed the batteries and still no light. Can you suggest a solution? I tried the connect button but no change. Thanks for any help!
usually there is a button on the bottom of the wireless mouse that you can push at the same time you push the button on the mouse adapter on the pc. Simulataneously push both and see if that doesn't help.
If that doesn't work, change batteries. If that doesn't work, uninstall the mouse and reboot. Software should reinstall.
Jul 06, 2010 | Logitech Cordless Mouse
Logitec mouse stopped working. Changed batts,
If light on bottom does not come on can only be one of 2 things
A Duff batteries
B Mouse is a bin job.
Aug 31, 2009 | Logitech Cordless Mouse
Mouse will not work. I can get green light flashing, but will not work.
If you recently change batteries you must reconnect the wireless circuit between the transmitter and the mouse. On the bottom of the mouse there is a tiny little button that says connect...hit it. sometimes that same button is located on the transmitter part, look for it and push connect or reconnect.
Now if this isn't a wireless mouse- well I just hope it is and that it helps you.
Good fortune...
Apr 21, 2009 | Computers & Internet
Logitech cordless mouse red light won't go off - New Batteries
Check the bottom of the mouse for a connect button. Push the connect button and it should work.
Mar 21, 2009 | Logitech LX5 Cordless Optical Mouse
97990 Rev. 4
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 30, 2009 | GE Wireless Optical Mouse
Hp wireless mouse model #m971au pointer stopped working
Make sure your batteries are good and then, Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 14, 2009 | HP Wireless Optical Mouse
Wireless Mouse not Working
Oct 23, 2008 | Computers & Internet
Mouse will not work
Press the button till mouse light comes on.
then try Normal 0 pressing the receiver button and then press the button on the mouse momentarily. This should be done whenever you change batteries or glitch.
Mar 20, 2008 | NexxTech NOM Mouse
My new Nexxtech NWOMMI cordless mouse is not working
Here is what I found about the Nexxtech Notebook Wireless Mouse (NWOMMI):
1. The 2 AAA batteries must be inserted correctly. Look carefully at the "+" and "-" marking on top of the battery compartment and put your batteries in accordingly. Otherwise the mouse will not work, and could be damaged. After the batteries are inserted, the red light at the bottom of the mouse should come on. More on batteries below.
2. Insert the USB receiver into a USB port. The blue light should come on. Press the little button next to the blue light and the light should start to blink,
3. Whild the blue light is blinking, press the connect button at the bottom of the mouse. It is the big black dot inside the white label. Check that the blue light on the receiver is blinking faster, and then change to a steady light.
4. Now check the function of the mouse by moving it on a texture surface.
5. If all goes well, your mouse should be working.
However, here is the bad news. Either due to bad design or some flaw in manufacturing, the mouse consume batteries like crazy. I used fully charge NiMH AAA batteries and they last for only a few hours! And the worst part is that, I checked the batteries when the mouse stop working, ONE of the batteries is COMPLETELY drained, in fact it registered a reverse voltage of -0.1 volts (a charged values is +1.2 volts). This is definitely engineering problem. Note that even when the batteries are in this state, the red light may still come on, and sometimes the re-connection seems to be ok (i.e. the blue light blink faster and then changed to steady). However, the cursor will not work when you move the mouse! Recharging the batteries and the mouse will work again.
Based on the above observation, the mouse instead of having a power-saving feature, it actually has a power-wasting feature!!!
Nov 12, 2007 | NexxTech NWOMMI Mouse
Logitech Cordless Mouse Logo
156 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
