Question about Intel Server Board SE7501BR2 Motherboard
Error message "8601 memory error" on Intel SE7501BR2
When i turn on the computer the message "8601 memory error" appear. How to resolve it?
    President:
  • 828 Answers
Windows is holding ram memory..........try knocking downing page files/storage not used.......use the task manager to manage ram better.......disable the junk? or freeramxp.load the barebones.........<<suggestions)))> solutions of the cuff...check that the ram sticks are OK....for the boards . check the boards. for any damage cracks/leaning caps etc.....for a system not to pass post! well.......is the Motherboard up to it......
Or this might be: "Memory errors status is now read from the BMC. Because this was not done previously, error status bits have piled up in the BMC and the first time you boot with this BIOS you will probably get a message saying all of your memory is bad (POST error 8601). To clear his status, enter setup/advanced menu and select the 'memory configuration' option. Enable 'memory retest' at the bottom of this menu and you will remove the error message. 'memory retest' option will be reset to 'Disable' in the next reboot.
"Remember to Clear CMOS after each BIOS update. Refer to the Hardware Maintenance Manual or Product Manual for procedures to Clear CMOS."
Found it at this link:
http://www-900.ibm.com/cn/support/download/attachment/JJIG-5EB3SZ/59p2195.txt
Please rate me.
Thank you.
Posted on Sep 05, 2009
Testimonial: "Thanks for the help. Another user help me about de problem, but, with your help the compreension of the problem was more complete. Best regards."
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
I am having Intel Board SE7501BR2, i wanted to know how much RAM does it support and of what speed, because currently it is having 512 mb ram with speed of DDR$266 mhz.
This motherboard can support up to 2Gb of DDR266 RAM modules.
Attached is part of the memory detail from the manual.
If you need a copy of the manual. please click on this link to download :-
ftp://serwery.optimus.pl/Servers/Motherboards/SE7501BR2/Dokumenty/se7501br2tps.pdf
3.1.2.2 Memory Configuration
Memory interface between the MCH and DIMMs is 144 bits wide. This requires that two DIMMs
be populated per bank in order for the system to operate. At least one bank has to be populated
in order for the system to boot. If additional banks have less than two DIMMs, the memory for
that bank(s) will not be available to the system.
There are two banks of DIMMs, labeled Bank1 and Bank2. Bank1 contains DIMM locations
DIMM1A and DIMM1B and Bank2 contains DIMM2A and DIMM2B. DIMM socket identifiers are
marked with silk screen next to each DIMM socket on the baseboard. The sockets associated
with any given bank are located next to each other.
The baseboard's signal integrity is optimized when memory banks are populated in order.
Therefore, DIMM Bank1 must be populated before Bank2.
DIMM and memory configurations must adhere to the following:
• DDR266 DDR registered DIMM modules
• DIMM organization: x72 ECC
• Pin count: 184
• DIMM capacity: 128 MB, 256 MB, 512 MB, 1 GB, 2 GB
• Serial PD: JEDEC Rev 2.0
• Voltage options: 2.5 V (VDD/VDDQ)
• Interface: SSTL2
• Two DIMMs must be populated in a bank for a 144-bit wide memory data path
• One or two memory banks may be populated
Table 2. Memory Bank Labels
Memory DIMM Bank Row
J8D22 (DIMM 1A), J8D15 (DIMM 1B) 1 0, 1
J8D7 (DIMM 2A), J8D1 (DIMM 2B) 2 2, 3
Note: Memory must be installed in pairs; DIMM Bank1 must be populated before DIMM Bank2.
Memory within a DIMM bank must be identical; between banks only the DIMM size may be
different.
Functional Architecture Intel® Server Board SE7501BR2 Technical Product Specification
26 Revision 1.2
Intel Order Number C13977-003
Figure 3. Memory Bank Label Definition
Sep 25, 2010 | Intel Server Board SE7501BR2 Motherboard
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
appears only with a certain software
program or print job, contact the
software vendor for assistance.
4 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all of the cables that
connect the MFP to the network or a
computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory
cards. Do not remove the firmware
memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears,
reinstall each DIMM, flash-memory
card, and EIO device individually,
making sure to turn the MFP power off
and then on again as you install each
device.
10 Replace the component that caused
the error message.
11 If the error persists, replace the
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
I have a problem with Intel server board se7501br2: when boot, it msg error: "Error: A voltage limit threshold has been exceedeed". F1->continue, F2->Setup Please help me fix it! TKS all! (sorry my...
The power-supply is producing several different voltages.
However, one of the voltages that it is producing is *NOT* within the "normal" range of voltages, and so you get the error-message.
Replace the power-supply.
Dec 27, 2009 | Intel Server Board SE7501BR2 Motherboard
Unable to install software win 2003 server on SE7501BR2 as it didnt detect bootable 2003 cd showing error unable to detect hard drive as we have 2 * 73 scsi pls suggest can it be possible to install redhat...
Okay, has the SCSI system been setup properly? you must adjust some hardware settings to tell the computer what device is the end of the string, and if it is not configured correctly, you won't be able to use some or all of the SCSI hardware. I would check all hardware settings and BIOS settings before attempting that again.
**WARNING** Do NOT open your computer unless you are properly grounded to your computer via ESD Bracelet. any static that is discharged (Usually you don't even see or feel) can damage computer components. Please use extreme caution when working inside a computer.
Ryan Frame
Creative Energy Associates Technical Center
Sep 03, 2009 | Intel Server Board SE7501BR2 Motherboard
Server board SE7591
have memory and hard drive with an op sys
Jul 31, 2009 | Intel Server Board SE7501BR2 Motherboard
Physical memory dump blue sreen
This is error message is primarily related to the physical memory of your system is not working properly.. or else it might be a issue with the slot for the memory on your computer.... i would recommend you to contact a local guy or else you can also try to reinstall your windows on the system...
Jan 22, 2009 | Intel Motherboard
Intel Server Board SE7501BR2 Motherboard Logo
421 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
