Question about Whirlpool 24 in. ADG6340iX Built-in Dishwasher
About a minute after switching on the dishwasher switches off then on then off and so on until I turn it off. Try again same thing
Mine has just been doing the same, I have had the water off today and air was in the pipe, it took 6 or 7 restarts to clear it, all is well now.
Posted on Sep 22, 2009
Wash programme sector not working and on off switch works when it wants to
Try disconnecting power to the dishwasher by turning the circuit breaker off. Leave power off for 15 minutes or so then power back up. Try the program and switch again. Sometimes this procedure reboots the program and solves the problem.
Jul 08, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher malfunction
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
I have a whirlpool dishwasher that won't start even though there is power going to it. I was told by someone at Lowes ro shut the breakers off for 15 minutes and that would no doubt fix the problem. it did...
Check there is no water in the tray under the machine.
There will be a switch that turns off everything if there is a possible leak - so may be that. Just blot up any water and try again.
If there is a slight leak - trace it.
May 02, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
On off switch won't stay depressed on AEG dishwasher
Took unit apart and when I put it back it worked again. For how long who knows.
Access to the switch is difficult but by removing the printed circuit board, it seemed to allow the switch to work.
Dec 27, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Silly Dishwasher
press and hold scrub and delicate at the same time for 3 seconds then let it cycle turn off it should reset.
May 15, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut ...it continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
Brand new dishwasher not working
try this test: add water (one gallon each try) by hand fill and try the cycle again. Continue until light goes out. If light never goes out, then faulty water level switch or wiring. If light goes out, then water inlet valve is stopping too early, but need more info to determine why. Try this test: open door and find the door switch. Then activate the switch and turn on machine to watch water come in. It should not just "dribble" in; try to determine if water pressure is sufficient coming in.
Jun 19, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool 24 in. ADG6340iX Built-in Dishwasher Logo
124 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
