Washing machine LG model WT-T902A
My washing machine won't drain. The "no drain" light displayed towrds the end of a load, and I can't locate my manual to troubleshoot.
I pretty sure that the motor is ok. I bucketed out the water, and ranthe machine empty for a load, and it was fine until the same point it stopped the first time.
HELP!!!! Thank you
    President:
  • 1,294 Answers
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Dec 08, 2007
  • prem mathew Dec 08, 2007
    Click on (your brand name) of washing machine, that is.....
    You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
    And rate me pl, if the solution has worked......
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
LG WM0642HW
make sure it drains the water out..it will not go through spin if there still water inside the tub... also drain is timed. Is there any error message? thx
Mar 01, 2014 | Washing Machines
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Won`t spin.
heatman101
Aug 14, 2011 | LG WM1814CW Front Load Washer
My LG WT-R807 8KG top loader washing machine will not rinse or spin I have a huge load in there at the moment. Have removed most of washing from it still won't drain. Have tried turning machine off and...
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Jul 14, 2011 | LG Washing Machines
It won,t spin
heatman101
Sep 16, 2010 | LG Washing Machines
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
Where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
Mar 14, 2009 | LG WM1814CW Front Load Washer
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
