Question about HP Photosmart 2710 All-In-One InkJet Printer
Error Message: Ox886a6916
On/Off switch does not appear to work. When power plugged in the above error message occurs. Any procedures to correct this or is a technical repair required?
  • chrissy082 Aug 11, 2008
    Ox886a6b72 is what my error message says. Also, the copy, scan, fax, and photo buttons blink continuously, along with the on switch.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
I understand that you are unable to work with the ON/OFF button on the printer. I suggest you to perform the following steps provided.
Please do connect the printer directly to the wall outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
As this is a hardware issue with the printer you can contact your nearest service center by the help of the following link.
http://hp.via.infonow.net/locator/us_partner/
Regards,
Sagar.
Posted on Jul 27, 2008
How can I fix an error msg #6A81 on the Pixma mg5320?
Error 6A81 is described here: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 19, 2016 | Canon PIXMA Office Equipment & Supplies
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
WHAT IS ERROR E046 CANON SCANNER
E046 Main drive PCB
(Controller CPU judgment)
If a communication error occurs between
the motor or sensor and PCB, an error
message appears. If it appears, reset the
main body and computer power. If the same
error message/code still appears, check the
connection of the related part, and if it is faulty,
correct it. If there is no problem with connections,
replace the related part. For motors,
check the connected drive transmission parts
and operation check sensor as well.
May 12, 2014 | Canon Dr-7550c Color Duplex SCSI-Iii USB...
Error SC305 on
An error has occurred in printing.
  1. Make a note of the error message (for reference later).
  2. If the error re-appears, please contact your local authorized sales/service representative or original point of purchase.
For the time being, try restarting the device:
  1. Press the Clear button to clear any pending jobs from the Printer.
  2. Switch off the device at the Red Power Switch, wait for 5 seconds then switch on again.
May 07, 2013 | Office Equipment & Supplies
Error message on mfc-8890dw unable to print 6A
Hello Robert! Welcome to FixYa!
Unable to Print 6A error in Brother Printer is an error of Fuse Failure.It is due to problem of Fuse Assembly. This error is usually solved by the following procedure:-
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
If above procedure doesn't work then sometimes it solve by given procedure:-
1) Unplug the printer power cord.
2) Hold down the menu key while plugging in machine at same time.
3) Enter 99 while holding down menu key
4) After menu says " wait" push the stop/exit button to get out of the maintenance mode.
If that does not work too, it means that the fuse assembly must be replaced. If your printer is still in warranty then claim the warranty. If it is out of warranty then you have to contact authorized service center of Brother Printers to replace the Fuse Assembly.
I hope this solution helps you and you have clear picture in your mind now
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Jan 03, 2012 | Office Equipment & Supplies
I have a rather old Whistler 3300 radar detector with the antannae unit in front of the radiator and the suction cup unit on the front windshield for rear detection. I've had it forever and love it. ...
Here are the steps from Whistler's FAQ page on their website:
When the display shows an "R1" type error on the display or the unit clicks (flashing either the Green power LED or the Yellow city LED), it means that the link between the inside and outside unit has failed. Generally this is caused by the receiver's (outside unit) cable becoming unplugged from behind the console (inside unit).
NOTE: The receiver cable is the straight one plugged into the "Radar 1" jack. The laser receiver (LRM-5) cable is angled and plugged into the "Laser" jack. This error will also occur if these two cables are reversed.
Follow the below steps to correct R1/Clicking error message:
  • Make sure the correct cable is connected to the correct jack and that it is fully engaged.
    Make sure there is sufficient slack in the cables to prevent them from "walking out" of the jacks.
  • Follow the Factory Reset procedure.
  • If the above suggestions does not cure the problem, email our Customer Service dept for more information.
Follow the below steps to correct R2/Clicking (Not available on Pro-3450) with "R" Yellow LED flashing error message:
  • If the rear antenna was not installed, go to the Factory Reset procedure. If a rear antenna was installed, continue to the next step.
  • If the rear antenna is installed, it must be programmed.
    For models 2270 and 2290
    1. Remove power from unit
    2. Press and hold the Dark button
    3. While holding the dark button, apply power to unit and hold the Dark button for 5 seconds. The "R"LED and either the Green (highway) or Yellow (City) will illuminate.
    For model 3300 and 3400
    1. Unit will display "R2 ON ?"
    2. Press the Dark button for Yes or City for No.
  • To temporarily cancel the "R2"error message on a 3300 or 3400 model, press and hold either the Dark/City/Quiet button.
  • Follow the Factory Reset procedure and see if the "R2" error goes away. If so, go to next step.
May 29, 2011 | 3300 Radar Detector
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
Error message appearing "power failure occurred
Push the Start/Stop button on the Neptune to reset the machine.
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
333 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
