Question about Kodak EasyShare C713 Digital Camera
My EasyShare C713 won't turn on even after I insert new batteries
It worked a couple of weeks ago and now won't do anything. I've tried several sets of fresh batteries and it still won't turn on.
    President:
  • 2,761 Answers
It could be something more serious, but this problem is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Posted on Sep 06, 2009
I have had my Easyshare M853 for more than 3 years with no problems. A few days ago it just stopped working. It will not turn on, even if I change to the spare battery. When I plug it in to charge, the...
It's likely not worth getting repaired, no. In the world of digital cameras, 3 years is unfortunately pretty old. If you have tried two different batteries, that rules out the battery as the culprit. It's likely that there is a circuit inside that is fried and is interrupting the flow of power both from and to the battery. My only suggestion would be to take the battery out for a couple of hours then put it back in and see if that does anything. It probably won't but it's worth a shot. It's probably time for a trip to your local electronics store for a new camera...
May 05, 2011 | Kodak EasyShare M853 Digital Camera
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
Dec 31, 2009 | Kodak EasyShare C713 Digital Camera
Camera Kodak C713 does not turn on..even on trying new batteries..It is 1 year old..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare C713 Digital Camera
Even using new batteries the camera just wont turn on - kodak easyshare c713
Are You using the AA batteries?
Try to reverse the oirentation of the batteries, Instead of positive negative make it negative positive. I also have this problem same camera model what I did is that reverse the polarity of the battery,
MAke sure that you are using the recommended battery, If disposable you can used AA Alkaline and if rechargeable you can use KAA2HR battery or Ni-MH battery
Nov 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
The camera wont turn on
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C713 Digital Camera Logo
112 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
