Question about Hotpoint Aquarius WMA42 Front Load Washer
The washing machine has started creating holes in colthes during the wash, i have checked and there dose not appear to be anything sharpe in the drum What might it be?
Often this is because you have put too many items in the wash and they are pinched and rubbing. It can also be something like a sheet gets stretched out because of the agitation and is rubbing against something. Do you ever see it in a small load? You might just be overloading a tad. I used to have this with my old washer, it's a bummer.
Posted on Sep 05, 2009
I have a Bush F841QW Washing Machine since 18.04.2016,in the last couple months small holes have appeared in clothes following washing.This is very unsatisfactory,can you help please? Wendy Haydon
Have you examined the drum inside? Can there be a needle, nail or any other sharp item sticking in the holes of the drum, which puncture your clothes?
Take a close look and let me know.
Jul 29, 2017 | Washing Machines
My ASKO W6342 washing machine drum will not turn on any setting, it fills and drains fine but the drum does not turn during the cycle, however it is free to turn by hand, the belt from the motor is OK, I...
It seems a minor problem for me, but cannot say anything without checking your washing machine. You should better call washing machine repairer to fix this minor problem.
Mar 14, 2014 | Asko Washing Machines
Holes in colthes
It is time for a maintenance on the washer, Use a good observation lamp to check the drum , check for metal protrusion, check for drum settings.
click on : Maintenance
Jan 23, 2013 | GE Profile WPRE6100G Top Load Washer
My washing machine LG frontload model F1068Qdp is causing holes in some of the shirts and pants.I have noticed one edge of the drum is a bit sharp that might be causing this problem .Is there any solu
Holes are usually caused by overloading the machine - but a sharp edge is a major fault and you need to call the engineers out and or seek a replacement as a repair is a major undertaking.
Feb 01, 2018 | Washing Machines
My Bush A146q washing machine keeps tearing clothes.
Run your hand round the inner drum and look for sharp edges, also overloading causes torn clothing
Oct 04, 2017 | AEG Washing Machines
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
