Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Loud fan - ice build up in fan compartment.
It seems that ice builds up behind the freezer compartment to the point that the fan blades strike the ice. The only solution thus far is to defrost the area using a hair dryer. This last a week or two and then re-occurs.
  • jandbcoffey May 11, 2010
    Sorry - I can't afford your fees right now.
  • 3 Answers
Check resistance on bi metal thermostat/heating element.Make sure continuity is present on thermostat before defrosting.Advance derost timer if analog unit.
Posted on Sep 16, 2009
  • 90 Answers
SOURCE: Drain plugged in freezer
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Posted on Jan 17, 2008
mikedurland
  • 481 Answers
SOURCE: Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 21, 2008
  • 1462 Answers
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 25, 2008
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
  • 19 Answers
SOURCE: Need photo of freezer defrost sensor, switch or thermostat
Before replacing all of the components mentioned above, locate your defrost heater and check for continuity with an ohm meter,this will ensure no breaks in heater coil
Posted on Jun 29, 2009
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Our two door samsung has making noise from the motor and when you open the door it will stop. jackie.brincat@bigpond.com
Hi and welcome to FixYa, I am Kelly
The noise that stops when you open the door is the evaporator fan. If it sounds like blades striking something there is most likely too much ice in the evaporator coils and the fan blades are striking the built up ice. If it sounds like a vibration it can be bad bearings inthe evaporatof fan motor.
Ice build up is usually a sign of an automatic defrost circuit problem. The unit should defrost close to 3 times a day depending on the defrost control installed. What you should do is do a manual defrost session by unplugging the unit, removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. This will ensure that all of the evaporator coil ice has melted. (Yes it makes a water mess) Tidy things up and return the unit to normal service after your manual defrost session. NOTE: If you have an automatic defrosting problem the fan noise can repeat in as little as 2 days as the ice once again builds up on the evaporator coils.
DO the manual defrost, LISTEN for noise after 24 - 48 hours. No noise... no worries, NOISE after 24 - 48 hours = Defrost problem. Causes of a defrost problem can be the defrost control, defrost heating element, the defrost thermostat or a wiring problem.
Thanks for choosing FixYa,
Kelly
Feb 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
The right side of the fridge is not cooling well. the freezer is fine, but it also making a strange noise
Hi and welcome to FixYa, I am Kelly.
That strange noise your hearing is probably the fan blades of the evaporator fan striking ice build up on the evaportor coils. This symptom is typical of and automadefrosting problem.... or someone left the freezer door open for a very long period.
You can try doing a manual defrost by unplugging the unit and place a fan blowing into the freezer compartment / compartment making noise for about 2 hours. (makes a water mess) After 2 hours tend to the water mess and restart the unit. Most likely the noise you heard will be gone... for a few days. If you have an automatic defrost problem the noise will return in about 72 hours as the ice build up gets larger on the evaporator coils.
Depending on date of manufacture this unit can have either a manual defrost timer or an adaptive defrost control board that controls the automatic defrost. .
Kelly
Nov 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
It is still cooling but was making a loud sound unplugged it over night now it seems to be working again, what made sound and will it come back
Good day,
Motors make noise. There are three motors. One behind the rear panel in the freezer compartment.
Another in the back rear of the machine, called a condenser cooling, fan motor, and lastley, the compresssor itself which is locacated in he bottom rear as well.
One reason could be ice building up around the freezer fan motor and hitting the blades of the fan.
If it is a Whirlpool/Kenmore make then that fan motor could be going bad.
But without a make and complete model number that's all the info I can provide.
As well, we'll need to know how long it takes to re-appear, and if it is constant or intermitent noise problem.
Dec 12, 2009 | Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
167 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
