Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Wiring diagram for peavey duel 212 7 pin din footswitch
5 Suggested Answers
rockdiarylv
  • 27 Answers
SOURCE: Peavey signiture EX wiring
if the signature ex has any special plugs then the actuall diagram for that guitar is needed. but if it uses the standard two or three potential meter ( volume knobs and tone knobs or (pots) ) with a pick up selector and an input. then you can use any guitar wiring diagram and i think you can find that on web. wiring the pick up should be shown in the diagram with the pick up selector.
Posted on Feb 27, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: Peavey signiture ES wiring
Go here: http://www.seymourduncan.com/support/wiring-diagrams/ and select your guitar's pickup/control/switch configuration from the dropdown menu.
Posted on Jun 20, 2009
  • 226 Answers
SOURCE: Peavey valveking 212 - no pilot light on power on
Hi, are you saying , the sound is very low?
Are the valves ok and do you have the correct voltage going to the heaters?
Looking at the diagram, are the valve mounted directly to the PCB's, if so go over the solder joints and make good any dry joints.Very common in all valve amps.
Check for any leaking or bulging capacitors, a capacitor checker will come in handy here, just measuring them with a meter is not really good enough..
I am still looking at the schematic, so bare with me as i'n not really a valve person, but i'm gonna help.
Regards - Anthony
Regards - Anthony
Posted on Mar 03, 2010
  • 5603 Answers
SOURCE: Hi , I have a
The footswitch just has two toggling buttons that connect either the tip or ring or both of the TRS plug to the sleeve. Very low-tech... make your own.
The buttons are alternate on-off action ones.
Posted on Feb 06, 2011
Peavey renown 212
If no fuses blown you probably have an issue on your +15V and -15V power supply regulators, this can be tested by checking opamps supply voltage which should be +15V at pin-8 and -15V at pin-4, let me know further.
Jun 22, 2013 | Peavey Music
Wiring diagram for peavey delta blues footswitch
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Oct 25, 2012 | Peavey Delta Blues Footswitch
NEED WIRING DIAGRAM FOR RENOWN FOOTSWITCH
Aug 10, 2012 | Peavey Music
I have and old Peavey Mark IV bass head. I want to know if it is possible to remove the crazy 8 or 10 pin footswitch input and replace it w/ a 1/4 in plug. There is only two wires running to this craz
2 wires plus ground needs a stereo 1/4 plug. Don't know Mark 4, but Mark 3 has 2 button fs with 3 wires plus ground. Schematic here: http://el34world.com/charts/Schematics/files/peavey/peavey_mark_3_bass_with_pa.pdf
shows 3 wires plus ground. Stereo plug does not have enough connections, only ground plus 2 wires.
Count the pins of socket and find DIN plug with proper pin-out for socket. Search google for DIN plugs.
May 02, 2017 | Music
I have the fender accessories footswitch and the cyber twin. The pedal has stopped working and I have replaced the cable but still does not work. Is it the pedal or the amp? The amp buttons still work...
Verify the footswitch with an ohmmeter. You should find that each of four pins should have continuity to pin 2 of the connector when the switch associated with the pin is pressed.
Note the pin numbers on the connector seem to have a weird layout. Here is a link to your amp schematic. The Footswitch interface is shown on page 3 of 12.
http://elektrotanya.com/fender_cyber-twin_sch.pdf/download.html
Use the ohmmeter to check each wire in the cable is good. SOme cables, unless the official one for the unit, may lack some wires.
The amp "reads" the footswitch state into a register which is then read serially. The inouts are pretty well protected from user mistakes. With the schematic you should be able to analyze the failure.
Feb 27, 2011 | Fender Accessories Footswitch for Cyber...
Hi , I have a Yamaha RA50 rotary amp ...what kind of stereo footswitch should I be looking for to suit this unit .Would a Peavey stereo footswitch do the job ? thank you , Michael
Feb 06, 2011 | Peavey TwoButton Stereo Footswitch
Regards - Anthony
Regards - Anthony
Feb 28, 2010 | Peavey Audio Players & Recorders
I have peavey 212 heritage guitar amp footswitch plug broke. I have new one but i need wire diagram please include colors and speaker conection.Thank U very much
Call the Peavey Customer Service line (number available @ the Peavey site) and get the parts department to email you a schematics on the amp... it has the footswitch wiring on it. And it's free to do this.
Apr 27, 2008 | Audio Players & Recorders
Open Questions:
Car Audio & Video Logo
691 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
