Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Code 19 repair needed for the DVD drive - HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
  • 250 Answers
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this imagecode 19 repair - vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imageIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Now go to the "Did this fix the problem?" section. uparrow.gifBack to the top Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on Sep 05, 2009
  • HP Master
  • 13,433 Answers
Tsst corp dvd rw ts l633b code 19
u need to change the dvd drive... faulty lens or motor of the dvd drive
Jan 13, 2014 | Computers & Internet
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
Computer doesn't recongnize the cd-dvd player code 19
get a latest software of your notebook and find the driver of cd/dvd drive
Aug 12, 2012 | Gateway NV5378u Notebook
My 19 in magnavox tv dvd combo makes a rattling noise after i put a dvd in and try to play it
Sounds like you have something in it or the gear drive is bad. Open the door and look inside with a light. If you do not see any loose objects then I think you have a bad drive gear which would not be feasible to repair given the price of a new 19 in tv and dvd player...
May 05, 2011 | Televison & Video
Code 19- philips cdrw/cvd scb5265 ata device how do i fix it
Do you receive the following error message?
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19)
Code 19 is a common error message, your computer sends because NERO, Roxio, and similar CD/DVD recording software and also and update for Windows VISTA (KB938194) is causing issues. It can create problems with your sound as well.
Even if you uninstall these it will not resolve the issue, because these programs leave the problem inside your registry.
What is happening to your computer?
Device Manager sees the drive, but you get the yellow exclamation mark and it indicates "Your registry might be corrupted. (Code 19)"
How most people try to fix this error – and you are probably doing the same - without any luck…
If you try to uninstall the device and the driver and read new hardware - no change.
You can try to update the driver and the wizard will say there is no better driver found for the hardware.
You can try to run the install CD (copied it to a flash card and ran it from a flash card reader since you can't run it on the DVD drive) - same problem will occur.
You can't do a repair install of Windows since it is on CD and it won't boot properly from the drive.
You can try to use an external DVD writer (HP dc5000) through the USB port and it will get the same code19 error.
Even if you try manually copy the drivers listed in driver details for the device - no luck
Jun 14, 2010 | Samsung Philips CD-RW Kit 4x4x32 ( CDRW...
Matshita DVD RAM driver Problem
You have a code 19 error and need to delete some filters that have been put into your registry. There are directions of how to delete them here:
http://www.windowvistarepair.com/VistaBlog/known-vista-issues/dreaded-vista-error-code-39-code-31-code-32-and-code-19-60/
Jan 05, 2010 | Computers & Internet
My presario Cq60 cd/dvd drive not working. Driver is latest update. Message in general within device property is-configuratio in the registry is in complete or damaged code 19
From your description I understand that the DVD drive is not working and you have code 19 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Dec 22, 2009 | HP Compaq Presario CQ60-249US Notebook
Error Code 19
Replace the drive if it has not become unplugged.
Jun 26, 2017 | Computers & Internet
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
