Question about Whirlpool AWM6120 Front Load Washer
Whirlpool AWM 1250 wont drain
Machine washes then wont drain, rinse or spin. Opended up machine checked hoses for blockages and kinks, all clear and belt is in good nick
  • Eltel4 May 11, 2010
    Have you checked the output filter usually on the front of the machine? Also have you checked the drain pump itself for blockages. I have found coins in them in the past that act as a choke and then finally block the output, if you undo the sping clip on the machine side of the pump and the machine naturally drains, the fault is a blocked or faulty pump. If you have any doubt about the pump, change it as the impellors are easily damaged by foreign articles.
  • 1294 Answers
SOURCE: drain hose not working
You simply have to check your drain hose and exit filter; the problem is there. When yr machine does not drain it is surely the exit filter. Refer to your user manual.
Posted on Oct 07, 2007
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
rachael
  • 4 Answers
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
SOURCE: Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Posted on May 07, 2008
hemantraj
  • 638 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
the problem is solved in this link
www.applianceaid.com
Posted on Aug 29, 2008
What is the problem why water does not drain after rinse cycle?
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
Aug 12, 2014 | Electrolux Washing Machines
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
My Neptune is shutting down with a SUDS error
If machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
My fisherpaykel top loader washing machine wont drain water or spin it beeps and 3 lights come on
I worked out that code to be 37
info for fault 37
37. (00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3
minutes. There are three likely reasons for this fault. One is that the drain hose or the
pressure switch hose has been squashed or kinked and the pump out rate has been
dramatically reduced. The second possibility is that the pump is partially or fully blocked.
The third is that the pump is not operating due to Motor Control Module, wiring or pump
failure. This fault could also appear if the machine is pumping to an unusually high head of
drain hose or into an extended length of drain hose. The fourth possibility is a diverter
valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation
mode, giving the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action: 1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 1-metre extension hose of the same diameter
fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain
hose is not blocked.
5) If the bowl contains water, then service the pump from the top of
the machine by removing the top deck and inner bowl. Bail out the
water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action: 1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
pump is rotating. If it is not operating, and Primary and Secondary
checks have been performed, then replace the Motor Control Module.
Dec 05, 2012 | Fisher and Paykel Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Whirlpool washing machine AWM 5100 has stopped going thru the full cycle.
My machine did a similar thing and in my case, it was debris in the filter. It took several clear-outs before the object appeared.
Mar 21, 2012 | Washing Machines
Have the Indesit Moon washing machine and it will not finnish the wash cycle and go into spin mode. Is there anything I can do? Thanks
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Apr 14, 2010 | Indesit W 123 Front Load Washer
My washing machine will wash but when it comes to rinse & spin it wont & wont drain to can u help thank you ?
  1. 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Apr 10, 2010 | Tecnik TKL9260 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
The washing machine is not draining the water away, so i can not get my washing out
It must be the drainage hose, the water cant go anywhere else. The majority of the drainage hose is out of view, unless you've taken the whole thing apart, so it must be blocked.
Hopefully, it will be under warrenty, or you're looking at arounf £70 for someone to come out and fix it.
In the future, every three months or so, put your washing machine on the hottest cycle with clear vinager, and a dash of bleach; this will help unblock any potential blockages.
  1. step 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. Step 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Step 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Step 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. Step 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool Washing Machines
Whirlpool AWM6120 Front Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal De
