Question about Dell Inspiron 1521 Notebook
Microphone distorted sound
1521 laptop using skype or logitech vid when speaking microphone sound is distorted at other end. you can be heard but not clearly
have internal webcam also tried logitech quickcam deluxe webcam same problem
video clear using vista sp1
  • 313 Answers
You need to get into you setup for the micro phone to adjust the the output or the gain. look under the sound management in the control panel
Posted on Sep 08, 2009
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
No sound is heard with calls on Skype, I get video, and i hear sounds made by the program, but no sound from the recipient of the caller. I get sound when I video chat Mac to Mac, but not Mac to Windows,...
Ok, by the sound of it both yourself and whoever you're calling have not set up Skype quite right.
On your end, you need to:
  • Make sure you have a working microphone - try using Skype's built in 'Echo' feature (try calling 'echo123')
  • In Skype -> Preferences -> Audio, make sure that microphone is selected.
On their end, make sure they've done the same - they must have a working microphone, correctly setup with Skype in order to send you sound.
Hope that helped!
Jan 18, 2011 | Apple Customized 15" MacBook Pro Laptop...
Windows Vista. Using Skype, the person on the receiving end can't hear me. If I am running iTunes on that computer, though, the recipient can hear the music, just not my voice. I can hear them.
Hi
Start skype. Choose the menu calls then sound settings, select the device through which to speak: web camera, if you are using a built-in microphone or any other bluetooth headset if you are using or external microphone
Oct 03, 2010 | HP Pavilion dv1000 Notebook
I'm trying to use skype with my webcam but can't get sound. Also the circle around the logitech logo dosen't light up however when I'm in photo booth it does. Can I turn on the webcam somehow? Thanks
If you have a laptop make sure your webcam mic is set to default before you go to Skype
Laptop x Vista x Skype
You may have to access your hardware from the Control Panel if you have an earlier OS
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab, ramp up slider ( adjust to suit later) > OK
Return to "Recording". Test mic by speaking and make sure volume graph displays CONFIGURE TO SKYPE
Start Skype
On the Tools menu, click Options.
In the navigation pane of the Skype Options window, click Audio Settings.
Select your webcam as the default microphone.
Save
In your Inbox make a test call using Echo/Sound test.
Oct 07, 2009 | Logitech Webcam
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
Cant get my mic to work
DOWNLOAD NEW DRIVER FOR IT ,,GO TO THE DELL DRIVERS SITE
May 15, 2009 | Dell Inspiron 1521 Notebook
My problem is with a Logitech WebCam with a built-in Microphone. The Mic does NOT work . It works on another LapTop ( with the same Vista ) but not in here ( PC with Vista ) I tried most of the the trouble...
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Apr 07, 2009 | Logitech Webcam
Playback distortion
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 09, 2009 | Logitech QuickCam Communicate STX Personal...
Static in between video
Second reason is, if you are using a laptop and have and have added an external microphone between the two it will cause distortion and static.
Jan 02, 2009 | Logitech QuickCam Communicate STX Personal...
Microphone muted in Skype window, visuals OK, cannot be heard
you need to use the skype set-up call for cam and mic.RICHARDM69
Dec 09, 2008 | Logitech Webcam
Dell Inspiron 1521 Notebook Logo
674 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
