Question about Admiral AW22 Top Load Washer
Amiral top loader3Ratw3005tq When cycle finished clothes covered with small black flecks which looks like scale ?from the lining of the outside drum The machine is 9 months old. thanks Klaus
  • drkmderm Sep 06, 2009
    Any other suggestions?
    any other thoughts - definitely not the clothes or grease-the black bits are like soft flakes - when they dry they can be brushed off the clothes and disintegrate to powder
  • 491 Answers
Remove the hoses from the water inlet at the taps and/or at the back of the washer and check the filters in the hoses for the same flecks trapped in the screens.
If yes....the flecks are coming into the washer from the water supply.
If no.....run a empty load with a full water level with a product to remove rust,calcium and lime.
Make it strong.
Run the same full level wash cycle again with bleach.(strong)
Is the drain hose clear....does the machine quickly drain well?
If the flecks continue......you may have to use your warranty to correct the problem of a defective tub and or agitator.
Save some of the flakes for the repair people if you have to use the warranty.
Posted on Sep 06, 2009
    President:
  • 1,197 Answers
Hard to tell what the spots are without seeing them... But... If they're black greasy spots they could have been caused by the washer. As for the clothes, I'd suggest wetting the spots with liquid detergent, rub it in and wash them again... Now then, if the spots are lighter it may have been the detergent or fabric softener
You need to try a process of elimination to figure this one out. It could be the detergent which should be put in before the clothing or diluted with water. It could be dryer sheets or liquid fabric softner and yes even the body spray. Change one of the things at a time untill you can figure it out.
fill your washer with water then add a couple of cups of white vinegar and then run it through the cycle without any clothes in it , the vinegar will rid your machine of any deposits that should not be there
My first guess is that it's rust coming from your washer,if you eliminated most of the other possibilities already.
However, there's one thing that may be different: do you use different temperature water on dark clothing from what you use on light colored clothing? If so, whatever is causing the stains could be coming from your water heater and it's simply more noticeable on dark clothes.
Obviously your water is an issue, but it doesn't fully explain the mystery. The above are guesses, but I hope they might lead you to a solution.... but it would be just guesses like this unless the machine is opened and checked ..... since your unit is under warranty (only 9 months old)..... you cannot do this as it would void your warranty if you open the unit.....
if you have tried all the above possibilities and still you get them..... something is rusting away inside.... i would advice you not to waste anymore time and call the manufacturer at the earliest.... sometimes allowing the machine to function with a defect could make it even worse...
regards iversh
  • SAM JAYANTH CHANDRASEKAR
    shud u insist on doing this repair urself inspite of voiding the warranty claim.... Pull off the agitator (7/16 bolt below the top) and check for a bad tranny spidle seal.Clean all the grease off the agitator. Also, you may need to pull the spin tube and install a new seal.
    regards
    iversh
  • 601 Answers
Try to clean your washing machine .Every now and then grime bulids up in the machine after constant washing .So we need to clean them out every now and then. Run a warm to hot cycle on a medium size wash 1 cup of vinegar and a cup of cloudy ammonia,with out any clothes.Let the cycle run through out the end.If you are able to change the rpm spinning speed on the machine,then do so when cleaning it, to the lowest speed.
Hope this helps
Thanks
Smith.
Posted on Sep 05, 2009
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Maytag washer will hum but not start
It may have tossed the drum off the rollers. To fix this, you need to take a look at the drum rotation assembly (the rollers that hold the tank you put your clothes in viewed from the outside after removing the back cover) that could be a combination of fan belts and rollers or just rollers that are engaged to spin or agitate the wash cycles. I had the same problem and had her back in line in about 30 minutes of taking the back off, figuring out why it wouldn't spin and setting it back on the caster rollers to function. It's pretty easy to see, good luck!
Oct 01, 2012 | Amana ALW880WH Top Load Washer
I have my LG Fuzzy Logic for 3 years now. Lately after washing my clothes I see that there is black particals stuck to my clothes after washing. I comes off when I shake the piece of clothing. I has a...
It's just a build up of residue. To clean out your drum, run a hot cycle (obviously with no clothes in the machine) with half a cup of vinegar then when the cycle is finished, wipe out all the residue, and trust me there will be alot. I do this every 3 months to give the drum a good clean out.
Oct 29, 2010 | LG WFT1071TP Top Load Washer
Small flecks of dirt on clothes
If its noisy too then sounds like drum bearings gone / leaking oil/grease...
Apr 12, 2010 | Washing Machines
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirpool cabrio won't spin cycle
I just paid $85.00 for a tech to come out and pull some socks out that got stuck between washer drum and outside plastic drum. It took 10 mins. top.
It seems when you pull clothes out of washer small items slip between inner and outer drums. BAD DESIGN.
Jul 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dirty steaks on clothes at end of wash cycle.
Make up a couple of liters of a strong solution of hot water and Soda Crystals, pour that mix into the machine without any laundry in it and do couple of very hot washes
Change your soap powder to one of the old fashioned ones for a month or so and see how you get on.
Cold washing tends to leave body fats and other greases inside the machinea s there is little to break them down in "Modern" powders
Jun 19, 2009 | Washing Machines
OKI Laser Printer C5300 printing on paper with black flecks
IF you are using after market black toner then we found your problem. Putting a real toner on now wont help cause dodgy toner is now in the drum, you need to replace Black drum and use real toner. If you are using gen OKI toner, then just replace the Black (K) drum.
Clean led head and these printers dont need a teco, they are designed for wearing parts to replaced by operator ie Transfer belt, fuser, drums and toners.
Nov 20, 2008 | OKI C5100n Laser Printer
Dirty washing
Does your washer smell? Is your rubber door seal gungy too?
If so then use 1/2 cup of Washing Soda Crystals (50p for a 1kg bag from most supermarkets)
set washer to 60 degree wash and run machine for full hot cycle with no clothes in it... just the Washing Soda.
I did this with my washer which literally reeked, and my friends have since done theirs and the results are amazing...
Go and check your drain when you finish too... mine sparkles now and it was gunged up before.. I now add a desertspoon of Washing Soda to every wash.... I place it in the crease of the door seal and little by little all the mould is disappearing, even though the hot wash cleaned the gunge the black spots remained. My washer smells so clean now and no more black flecks on the clothes either... (these are loose gunge from the outer drum, right inside the works of your machine...)
All the best
Sue
Aug 02, 2008 | Hotpoint WF430 Front Load Washer
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
Admiral AW22 Top Load Washer Logo
26 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
