Question about HP w1907 LCD Monitor
Monitor starts then goes off, no signal
When I turn on the monitor it starts up, displays the icons etc. then displays, VGA Active, No Signal then screen goes black
  • 788 Answers
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Posted on Sep 12, 2009
  • 102 Answers
Most probably the wire is lose otherwise display card gone bad.
Posted on Sep 05, 2009
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
No signal when i used vga monitor connector to pc, no problem in dvi
Michael,
I have both ASUS and LG monitors with multiple input choices. On both, when the monitor is turned on, it remembers the last input source. Both monitors (and presumably yours, as well) have an INPUT selection in their SETUP MENU.
So, I'm suggesting you search your monitor for an INPUT selection option, then choose "VGA" rather than DVI / HDMI / AV / COMPONENT / CABLE / ANTENNA, etc.
Hope this helps.
Sep 02, 2014 | Acer Computers & Internet
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Mar 28, 2014 | Computers & Internet
How to fix my monitor when its in sleep mode
I assume this is a Desktop computer:
The Monitor receives, graphics or text from the PC (personal computer) and displays it on the screen.of the Monitor.
If you see a message on the screen that says * NO SIGNAL * in most cases the Monitor is good, and the Monitor is either not connected to the PC or there is a problem with the PC Check the connections and the video card.
The problem could also be related a failure of the motherboard, memory or the processor
Let us know..
Nour Sabre
www.aaatvservice.com
May 21, 2012 | HP W2007 LCD Monitor
What cord do I need to connect my 1810 gateway monitor to my tower
Your either going to need VGA or DVI. You need to check the back of your computer and monitor to see which type of connection you have. Then plug in the appropriate cable.
Pic of VGA cable: http://www.ccrzone.com/attachments/Image/VGA_M-M_6_.jpg
Pic of DVI cable: http://farm4.static.flickr.com/3216/2995518986_9deb622bff_o.jpg
Jul 19, 2011 | Gateway FPD1810 18.1" LCD Monitor
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
My VGA signal is active but I have no DVI signal.
You must just have one port to be active.
Let's say you want to use the VGA then it should only be the one plugged-in and vice versa
you can't have both ports to be connected at the same time.
Feb 28, 2010 | HP Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
I cant get my acer aspire one to connect
your describe: connect a laptop VGA out to a monitor but no signal: you need check
1) newer monitor have two signal interface (analog or digital) and you may try to do a logical change the signal way by select buton
2) any laptop have two way display (local LCD or extenal VGA) change by the key (fn+f key showing creen icon)
Nov 08, 2008 | Dell E207WFP LCD Monitor
17" monitor has power running into it but when you press the power button, speakers crackle but no image on monitor & power LED goes off
see if the signal coming to the monitor is active...
you can check this be disconnecting the rs232 cable from monitor to cpu..
when u disconnect it.it will display the no signal icon on the monitor...else there is some problem with your monitor...
Oct 29, 2008 | Computers & Internet
HP w1907 LCD Monitor Logo
602 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
