Paper feed The paper doesn't always feed through far enough causing print to be located to close to the top when printing business cards. I'm using thin weight paper.
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Paper not feeding
This could be caused by several parts, the most likely is the paper eject sensor lever & spring being out of position. Get a stiff piece of A4 card such as the backing from a note pad. Make sure the print head is in the parked position (fully right). Position card in the feed hopper and push through the feed mech. Open the top and watch for the card to come through the printer. This should realign the lever and also clear any obstructions in the paper path. Always try to remove paper jams in the direction of the paper feed, pulling backwards can damage levers etc.
Please take a moment to rate this solution. Thanks.
Mar 08, 2009 | Epson Stylus DX4200 All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    I am printing business cards and I am using thick paper but colors come out dull looking but if I change the paper to PLAIN then the colors come out just perfect, full, vivid and rich but I am afraid that...
    Its most likely the paper you are printing on. It sounds like this is an ink printer. The way ink works is that it is absorbed into the paper you are printing on. Some paper pulls the ink too far into the paper causing it to look dull and faded. You need to make sure you are printing on paper that is designed for inkjet printers. There are a lot of companies that make special paper designed for printing your own business cards. I prefer Avery products since they have a guarantee.
    Check this link out for some options on InkJet business card options.
    http://www.avery.com/avery/en_us/Products/Cards/Business-Cards/_/Ns=Rank%7C1%7C%7CProduct%20Number%7C1
    I hope this is solves your issue....Violet
    Jan 23, 2009 | Office Equipment & Supplies
    HP C4280 incorrect paper feed
    Check your printer's capability.
    Buy the card stock they recommend.
    If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
    Walking there beats going nuts over stupid software or hardware problems
    Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
    Problem printing business cards
    I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
    Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
    Paper is feeding unevenly on black & white prints
    If the paper is lodged too far into the printer and can't be removed:
    1. Press the power button to turn the printer off.
    2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    3. Close the front cover.
    4. Press the power button to turn the printer back on.
    5. Resend your document to print.
    Ensure that:
    • The paper is a recommended paper for inkjet printers.
    • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    • The printer is on a flat, level surface.
    • The left paper guide is against the side of the paper.
    • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    • The left paper guide does not cause the paper to bend in the sheet feeder.
    • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    • Envelopes or the appropriate specialty papers are selected in the printer driver.
    • You are using a paper or envelope size supported by your printer.
    Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
    May 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Paper feed on Canon i 350n ink jet printer
    Ensure that:
    May 13, 2008 | Canon i350 InkJet Printer
    Won't feed paper while printing
    I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
    Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
    jasbo
    jasbo
