Question about Jenn-Air JMV8208A Microwave Oven
I need to change the venting from back of the microwave to the top? Also, I have misplaced the manual for it if there is one on-line as well. Thanks Kirk
  • 612 Answers
There should be although you most likely will have to pay for it. Most models only require that you take the cover off the top and put it on the back. There will be a plate on the top covering the vent hole, just take it off and place it over the vent hole on the back.
Please rate
Posted on Sep 05, 2009
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
The door on my GE advantium 120 fell off and I need to reattach it
take off the top vent cover , should be three screws ...hang the door provided nothing is broken off the door or the microwave.. after hanging put the vent cover back on. If your model has a little clip/postage size at the top hinge or if you think there is something missing at that location you may need that to keep the door from coming back off... It can be bought on line if your model needs it. some do and some don't if you found something near that area before the door fell off... then your model had one..
Nov 06, 2011 | GE Advantium 120 Convection/Microwave Oven
I have an old GE Microwave jvm240av001 and would like to know the specs so I can replace it. It is so old (1995) I can not find anything on line. Please let me know if you can help. Thanks so much!
Hi and welcome to FixYa, I am Kelly
(trim kit required)
For all newer units the dimesnions are
15 & 3/4" high 16 & 1/2" high hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
or call GE 1-800-626-2005
Use this link for all models OLD and NEW:
http://www.geappliances.com/service_and_support/literature
To get dimensions you look up installation manuals for each model.
Your manual cam up here: (1.51 Mb)
http://www.geappliances.com/search/older-pdfs/49-8621.PDF
Your microwave is not vented externally but your replacement microwave will be capable of being used in a non-external vent and an external vent cofiguration. Personally.... I would recommend the external vent installation. Either will work.
Thanks for choosing FixYa, Kelly
Sep 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave doesn't seem to be bringing the air up into the vent for exhaustion outside. It's brand new.
I presume that you can hear the fan running? If so, most over the cook top microwaves have an option to vent to the outside or simply recycle through the filter and vents above the unit. If you check your manual there should be instructions on how to change this configuration to suit your situation, but it likely needs to be done before you install the microwave.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137234.pdf
The above manual shows how to reconfigure the microwave from recirculation (as shipped) to external exhaust setup on pages 4 - 5.
Oct 10, 2010 | Frigidaire PLMV169DC Microwave Oven
I would like to know whether the factory blower orientation for MMV4205AA had changed since 2000. Was it changed from top vent to circulating (into the room)? If it did, when did this change...
Here are the instructions for re-orentation of the blower.
The unit is shipped in the room vent configuration. The blower is re-orented for a wall vent.
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-011
The page numbers for the manual are changed at the top of the document.
For roof vent configuration:
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-012
Wall plate installation is on page 13
Here are the instructions for the wall plate.
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-013
Kelly
Sep 13, 2010 | Maytag MMV4205 Microwave Oven
Samsung SMV blower installation
Most Microwaves arrive ready to vent back into the room. For filtered air returned to the room it should face toward the front. For top vent, point to the top. for rear wall vent point toward the back.
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
How to change light bulb
If it is plastic vent cover there should be 2 screws apporx. 4 inches from each end,remove them tip top out and lift out.
Apr 22, 2009 | Microwave Ovens
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air JMV8208A  Microwave Oven Logo
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
