Question about E-Machines etower 400i PC Desktop
Cannot Copy the File swenum.sys
Works fine on other pc
    President:
  • 3,278 Answers
From that error message, either your memory is bad or your operating system (Windows XP ?) has become corrupted.
Remove your memory and add one module at a time to test.
Run Windows repair. Since I'm unclear as to what you are trying to do (run install ?), you may or may not want to reinstall the OS.
Hope this helps.
Posted on Sep 05, 2009
2 Suggested Answers
  • 33 Answers
SOURCE: Cannot Copy the File P3.sys
Try to check your hard drive. Use a utility tool specially made for the manufacturer of your hard drive. Ex. Seagate Hard Drive = Seatools
Western Digital = Data Lifeguard.
Check for any errors or bad sectors on the hard drive
Posted on Sep 07, 2009
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Gateway dx4720-03 error 651 can't connect to internet
hello,
This error"Error 651" is caused by this file raspppoe.sys you can find it in c:/windows/system32/drivers/ rename it(raspppoe_something.sys) and copy the new file from a friend pc that runs vista .
Jun 10, 2012 | Gateway Computers & Internet
Error 651
hello,
Jun 10, 2012 | Gateway DX4720-03 PC Desktop
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Wireless not working pc told me error 651
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Altec Lansing Sound On Sony Vaio Not Working
Are you running Windows XP?
I recently had a customer with a similar problem on an XP desktop; I tried all sorts of fixes before finding the answer in an online forum - it was a problem with the 'Software Enumerator' see the link below and look for a post by 'Jurekos'
http://www.techspot.com/vb/all/windows/t-34101-The-driver-has-been-enabled-but-has-not-been-started.html
Or follow the summarised steps below:
- FIRSTLY CREATE A RECOVERY POINT IN CASE IT DOESN'T WORK AND YOU NEED TO UNDO CHANGES -
1. Check if PnP SW Enumerator is installed on your machine (Device Manager / System devices) - it should be listed there!
2. If it is not there then we will probably solve it!
3. Locate "machine.inf" on your OS, copy it somewhere and modify it as follows:
(find "ExcludeFromSelect=*" and remove the line or simply exclude it from processing by adding a ";" at the beginning)
4. Check the "machine.inf" file for location where SWENUM should be located (mine was reading: SWENUM.CoInstallers.CopyFiles = 11 ; %windir%\System32)
5. Find "swenum.sys" file on your XP installation CD (mine was in DRIVER.CAB) and copy it to the proper location (I am not sure if it is necessary but worked for me) You could also copy this file from someone else's Working copy of Windows XP if you don't have your installation CD
6. Go to Control Panel /Add Hardware and follow the wizard towards manual selection of device to be added
7. Select Add System device
8. Select Have disk
9. Navigate to changed machine.inf
10. from the list select standard devices (in the left list) and "Plug and Play Software Enumerator" in the right list
11. Finish the installation
If it still does not work reinstall the audio adapters' drivers
Post a reply if you don't understand any of the steps listed and I'll try to explain in more detail
Good Luck - John
Sep 16, 2009 | Acer Veriton 5600G PC Desktop
Sep 05, 2009 | E-Machines etower 400i PC Desktop
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
No audio device ....on my xp C-media ac97 audio device. This device can not start( code 10) What I need to do get back my sound.
It usually means that you don't have exact driver installed. But sometimes it's a problem with a Plug&Play Enumerator. I solved this problem several times. First try to install exact driver for your device from cd or website of your motherboard. If after installation of a new driver you have the same issue you may try this:
1. Chek if PnP SW Enumerator is installed on your machine (Device Manager / System devices) - should be listed there!
3. Locate "machine.inf" on your OS, copy it somewhere and modify it (find "ExcludeFromSelect=*" and remove the line or simply exclude it from processing by adding a ";" at the beginning)
6. Go to Control Panel /Ad HW and follow the wizard towards manual selection of device to be added
8. Select Have disk
If it stil does not work reinstall the audio adapters' drivers. It should work now.
And also if you have any Linux liveCd you can boot from it . Linux loads it's sound drivers and after when you boot Windows it usually solves your sound problem ( I resolved this with Mandriva One Live CD).
Mar 21, 2009 | Computers & Internet
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
E-Machines etower 400i PC Desktop Logo
488 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
