Question about Nokia N70 Cellular Phone
Application running in background
When i open applications like Contacts,Messaging, Camera - Even after exiting them i could see a task in a third party tool called FExplorer, where as the inbuilt task bar [holding menu button] is not reporting this.
Please advice.
  • 178 Answers
That software is not so reliable.
Don't see to it untill you see some problem!
Posted on Dec 08, 2007
My battery dies half way through the day without even using it, is there something running on the phone draining the battery?
Hi
BBM ( blackberry messenger) could be a drain, especially with that many contacts pinging you all day long. Is your brightness on high? That is another big power drag. What apps are you running?
What themes have you installed? You can try reinstalling the OS. Check what applications are running on your device in the background, press the Menu key then choose Switch Applications. You will see the icons of each application there.
There are commonly four or five applications that will always be running (Messages, Call Logs/Phone, BlackBerry Messenger, Home screen, and the Browser; there are other third party applications such as Bee Jive, and BlackBerry Alerts which will also run in the background which you cannot close if you want them to operate). Make certain that the browser is NOT on an active webpage (open the browser and choose Menu > Close). Close any other applications that do not need to be running (the camera or a game you were playing or Google Maps).Also make certain BlackBerry Maps is not running in the background.
Do a simple reboot: With the BlackBerry device powered ON, remove the battery a few seconds and then reinsert the battery to reboot.
Now, watch your battery use the next few days again and see how it goes. Make sure you close or exit ALL applications properly: If you just hit the red "end call" key to go back to the home screen the application actually stays open and running in the background. If you do this repeatedly you will have lots of apps open and consequently your memory will get used up. Lack of memory is the biggest reason your BlackBerry slows to a crawl or locks up. If you get into the habit of actually using the menu key to close the applications this will at least slow down this battery drain and memory-clogging process.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Mar 19, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Every time i open my yahoo messenger ..application error appears.
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Feb 15, 2011 | Yahoo Messenger
Yahoo messenger.exe - application error when i need to open my yahoo i received this error plz help? Yahoo messenger.exe application error 0xc150002
Jan 27, 2011 | Yahoo Messenger
I cannot open my Yahoo messenger I get an application error (0xc0150002). Can you help?
8. After Yahoo! Messenger is installed,run registry cleaner reginout cleaner also reboot your system. All other background applications will return to their original configurations.
Jan 23, 2011 | Yahoo Messenger
The application failed to initialize properly (oxc0150002) Click ok to terminate application?
Jan 10, 2011 | Yahoo Messenger
After installing YM10 always appear : The application failed to initialize properly (0xc0150002). Click OK to terminate the application.
Jan 04, 2011 | Yahoo Messenger
When i double click on yahoo messenger this is what is showing: "The application has failed to start because the application configuration is incorrect.Reinstalling the application may fix this problem"
Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Oct 19, 2010 | Yahoo Messenger
This application has failed to start because the application configuration is incorrect.Restailing the application may fix this problem
Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reg in out also reboot your system. All other background applications will return to their original configurations.
Oct 12, 2010 | Yahoo Messenger
Can get the cam to work says need to clase application even though nothing else open
Make sure its not running in the background hit control alt del then slelect task manager and check and verify its not running or stuck in memory, even a reboot will work also..
Thanks
May 15, 2009 | Logitech QuickCam Express Web Camera
Nokia N70 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
