Question about E-Machines etower 400i PC Desktop
Cannot Copy the File parport.sys
Works on aother pc without any problem from the same CD
  • 742 Answers
The CD Drive of your machine may need cleaning
Posted on Sep 05, 2009
2 Suggested Answers
  • 33 Answers
SOURCE: Cannot Copy the File P3.sys
Try to check your hard drive. Use a utility tool specially made for the manufacturer of your hard drive. Ex. Seagate Hard Drive = Seatools
Western Digital = Data Lifeguard.
Check for any errors or bad sectors on the hard drive
Posted on Sep 07, 2009
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Windows won't start
When you put in the XP CD and it boots off the cd, the XP setup files copy across, and at the 1st screen, you should be able to choose Repair. Press r, and this will start the Recovery Console.
When you are in the recovery console, choose your Windows installation (You will see what I mean when you follow the instructions.)
When you are sitting at the command line(C:\>Windows), access your CDROM drive by typing the letter followed by a colon, eg "D:". It may also be E:, F:, or G:.
When you have changed to the CDROM drive, type the following:
cd\ <enter>
cd\i386 <enter>
expand pci.sy_ C:\pci.sys <enter>
C: <enter>
cd\ <enter>
copy pci.sys C:\windows\system32\drivers <enter>
If it asks to replace, confirm.
Then restart the computer.
Regards
Riztech
Jul 17, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
File: \Windows\system32\drivers\wdf01000.sys status: 0xc0000098 info
Boot up from the DVD drive with a windows bootup DVD, or boot up in recovery console, Ok, rename the file Wdf01000.sys to Wdf01000.old and copy new file from the Vista CD back to local drivers folder. then you will be back in business.
May 19, 2010 | Acer Aspire 3680 Laptop
Acer Desktop Veritron M460 will not load Windows XP or Vista!
This problem may occur if the Ntfs.sys file is missing or becomes corrupted when you convert your hard disk to NTFS To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, anddrive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.I hope this helps.The other thing I can think of is maybe your harddrive needs a raid driver.If this is a sata drive and an old version of you os,the sata driver may not be already on the disk and you will have to insert one.Let me know if the first solution works,if not we can try the raid driver.
Apr 08, 2010 | Acer Veriton M460 Micro Tower Core 2 DUO...
Boot failure. I get this message: Windows could not start because the following file is missing or corrupt: system32DRIVERSpci.sys
For what i see in forums, this issue is really hard, since u cant even start windows in safe mode cuz its one of the drivers that loads even on it. I suggest u try to run the repair windows option from a Windows CD, or even reinstall windows.
U could try to look over the internet for a pci.sys file and copy it via ms-dos if u know how to work on it.
Nov 01, 2009 | Dell OptiPlex GX270 PC Desktop
Pci.sys
ya you can transfer that file but it is difficult as usual... you need to some dos and using this dos windows you can copied that file into your c: drive...
but i suggest try to repair with any xp cd
Mar 30, 2009 | Toshiba Satellite 4300 Notebook
Basic Input Output System drivers problem
Try to remake the disk or seek out a new copy else were. Sounds like you may have a bad burn. If a secondary copy does not help please let me know and I can try to help track down the missing files.
Mar 18, 2009 | ASUS SiS Chipset P4S533 (P4S533 PA W/LAN)...
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
E-Machines etower 400i PC Desktop Logo
177 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
