Question about Brother MFC 240C All-In-One InkJet Printer
Saying empty yellow and cyan catridges when they are new
I have tried taking them on and off and switching the machine off but still same problem
Reports cyan cartridge empty but it is not
please remove all catridge
clean inside on the catrdge place space
put back the catridge
Oct 29, 2009 | HP OfficeJet Pro k550 Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
My HP 6500 on install will recognize Cyan ink
Solution:
1. Try to determine whether the catridge is at fault. How so? Switch the Magenta with the Cyan catridge. Press OK.
2. If system indicates that the Magenta is not installed, you will know that the Cyan that you put there is at fault.
3. Touch the 9 mm. hole where you can see the sponge. Does the Cyan color transfer to your finger? If not, the catridge is empty or dried up. Replace or refill.
4. If the ink is normal, then use some toilet tissue to wipe the gold contact points clean. If this fails to solve your problem, take it to your dealer and ask for a replacement (if it fails to work in their machine).
5. If this fails, then the problem is within your HP 6500. You need a technician.
www.catherinecollege.net
Aug 08, 2009 | HP Officejet 6500 Wireless All-in-One...
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Have a mfc-210c brother ink empty cyan replace ink. have put in a new lc41y ink cartridge . machine says open cover and reinstall ink cartridge. sortof done this 20 times!look forward to some advice...
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
May 03, 2008 | Office Equipment & Supplies
Mfc 215c printer ink problem
yes. unplug machine from power outlet. take all carts out. wait 5 min. leave scanner top open when powering up again. machine demands carts. reinstall carts and ANSWER display.
DO run a firmware update afterwards (see brother homepage of your country).
Mar 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink cyan message
???????????? Brother didnt compute that first message (seal off)!
For the second message have a look at cyan. Its empty, too ;-)
Feb 20, 2008 | Brother MultiFunction Center MFC-440CN...
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
29 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
